Thumbs up on FOX 2.0s
Discussion in 'Suspension' started by Zombie Runner, Jul 1, 2009.
  1. Jul 1, 2009 at 7:22 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    updated: added pics
    so after installing my fox COs they were set WAY to high and rode terrible... a week went by before i got a chance to adjust them back down. well that was yesterday...and now they ride like a dream!
    those plus I took off my sway bar and I just float around over dips and bumps and anything else!:cool:
    I went to rockandroll offroad to check my nitrogen levels in them and fox said to have them at 200psi. allpro sent them with 60 in one and 130 in the other...:mad:
    but all in all Im very happy with my new COs:D
  2. Jul 1, 2009 at 7:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Jul 1, 2009 at 2:52 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    good to here.glad u like them.
  4. Jul 1, 2009 at 2:53 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Nice! How's the truck's stance?
  5. Jul 1, 2009 at 2:57 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Good to know you got them checked, i just got my rear icons recharged the level on them was a little off but they are both set at 200 now.
  6. Jul 1, 2009 at 3:06 PM
    stanman9
    stanman9 Well-Known Member
    Toytec co's and aal, tc uca's
    got any pics??
  7. Jul 1, 2009 at 3:22 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    does it take a special air/nitrogen gauge to check the resis to see what psi u got?
  8. Jul 1, 2009 at 3:26 PM
    Robtrd
    Robtrd Member
    Robert
    Riverside, CA
    08 TRD SPORT
    Were do you get dem recharge at?
  9. Jul 1, 2009 at 3:52 PM
    babbott
    babbott Foxtrot Uniform Charlie Kilo
    Tooele, Utah
    08 off road speedway blue
    Any type of pressure gauge will work. All most any motorcycle shop will have a nitrogen bottle. I know the place I used to work at has a couple. They might give you some funny looks when you ask them about the shocks on your truck. Or any Airgas retailer will have it. Anywhere that sells higher end welders and welding supplies usually has nitrogen, along with all their other exotic gases..... Either way, it might cost you a couple bucks to have them recharged. But deffinitely well worth doing.
  10. Jul 1, 2009 at 4:02 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    great, thanks babbott.good info.+1 for u.
  11. Jul 1, 2009 at 4:07 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I got them charged at the local 4x4 shop in town. http://rockandrolloffroad.com/
    great guys and they know their stuff.
    before I had the toytec coil spacers and i had 3" of lift,
    right now with the COs I have aprox 2.25" of lift...I need to get accurate measurements though.
    Oh and by using the small spaner wrench instead of the bigger one I was able to adjust them without taking anything apart. I just put my truck on some jackstands and used a small cheater bar to get better grip/leverage and it worked great.
    If anyone is on the fence about getting these COs I highly recomend them!:D
  12. Jul 1, 2009 at 10:43 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
    Congrats on ur c/o's ... now i just need the money. How much better do they ride than the stock suspension? like small, medium, alot. Do they do alot better on rocks and things?
    Thanks!
  13. Jul 1, 2009 at 10:47 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    nice...i noticed on my rears that are adjustable that each click makes a noticeable difference in the shock..very nice
  14. Jul 2, 2009 at 8:32 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I only had my truck a week before I put the toytec lift on it so Im not real sure how it rode from stock.
    But the difference from the spacer lift to the COs was a night and day difference!
    as for trail riding, I havent had a chance to take them offroad yet, I will this weekend though cause Im headed out to the lake! :D
    Now I just need to put in my 3 leaf pack from wheelers to help the rear out:cool:
  15. Jul 2, 2009 at 8:37 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Keason if you can please tell me how many inches of thread is from the top of the main spanner ring to the bottom of the blue on the top of the shock. I just installed mine yesterday (skyjacker version) and set them to what the directions said, they are way to low.
    Looks great!
  16. Jul 2, 2009 at 8:39 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    lookin sharp.
  17. Jul 2, 2009 at 10:03 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I used the install guide from wheelers and it said the have 4" of thread showing....well that was way wrong, my truck was way high and rode like a rock falling down a cliff...
    so i backed way off of them and this is what its at now.
    sorry I dont have a tape at my house...haha but ill try and get a good measurement this evening. I would say its about 2.5 inches of thread or so
  18. Jul 2, 2009 at 5:56 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Did you make up your own stainless hose for those reservors?
  19. Jul 2, 2009 at 8:25 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    nope, thats how they came!
