Thump from under seat on hard acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by njcoma, Jul 13, 2017.
  1. Jul 13, 2017 at 7:32 AM
    njcoma
    njcoma [OP] Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Replaced u joints at 80k. With greasable ones that I keep pulled full every oil change.
    It's a pretty significant slamming sound/thump that radiates through my seat when I accelerate hard on the freeway. There is no thump coming off a stop or slowing down.
    I'm thinking transmission mount? Thoughts? 06 prerunner.
  2. Jul 13, 2017 at 9:24 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Are you sure there isn't something under the seat that rolls around on hard acceleration?
  3. Jul 13, 2017 at 9:31 AM
    njcoma
    California
    Most definitely not. It's coming from the drivetrain.
  4. Jul 13, 2017 at 9:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    How is the center bearing?
  5. Jul 13, 2017 at 9:37 AM
    eon_blue
    Azusa, CA
    That sounds like dry or bad u-joints to me, my '04 does the same thing when I shift gears under heavy load...I can feel it "THUD" underneath me where the driveshaft is. It gets better when I grease it up. Weird that your's is doing it with brand new ones, I wonder if it's coming from the transmission and not the driveshaft? Transmission serviced regularly?
  6. Jul 13, 2017 at 9:55 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    If your certain it isn't the u-joints I'd check the carrier bearing. Also 05 and some 06 Tacoma's had weak motor mounts, maybe one is cracked or damaged causing the thud, would also be worth a look.
  7. Jul 13, 2017 at 10:00 AM
    njcoma
    California
    I'm at 104k now so my ujoints aren't exactly new. And when they went bad last time I shook so bad on the freeway the rearview mirror wasn't usable. So different symptoms
  8. Jul 13, 2017 at 10:02 AM
    njcoma
    California
    Yea I started reading about the motor mount issues today. Gonna crawl under it this afternoon for an inspection..
    And as for the center bearing.. It's original... I did the Ome drop bracket a few years ago to help relieve the 10-15mph shake.. It helped tremendously.. I may temporarily remove it and see if it gets better/worse.
    eccracer104[QUOTED] likes this.
  9. Jul 13, 2017 at 10:15 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Since you're a prerunner, there's no slip yoke. I know when I lifted mine the driveshaft was too short and kept pulling out the center of the carrier bearing. I ordered a drive shaft spacer to alleviate that and my bearings have been lasting longer. 104k is a long time on that stock bearing for a 2wd.
  10. Jul 13, 2017 at 11:35 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    My 05 did this on hard accelerations after my frame replacement
    I flipped my carrier bearing and it stopped
    the bearing is not perfectly center so flipping it lowers the d shaft a little
    on hard accelerations the shaft hits the trans tunnel
    2 min fix take out 2 bolt rotate bearing put back bolts
    didn't realize you had prerunner so i could be wrong
    Don't know if you have carrier bearing
  11. Jul 13, 2017 at 11:41 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Sounds like a motor mount. Common in tahoes and suburbans, mostly any gm v8 from 2007 to present. It's funny to watch a v8 jump 6 inches up in the engine bay.
