thump in front end
Discussion in '1st Gen. Tacomas (1995-2004)' started by trailinTaco, Apr 19, 2009.
  1. Apr 19, 2009 at 9:41 AM
    trailinTaco
    trailinTaco [OP] Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    i have a horrible thump in the front end when i go over speed bumps. I cant figure it out. i have a 3 inch lift with coil spacers and original bilstien struts. could it possibly be the front shocks fully extending?
  2. Apr 19, 2009 at 10:03 AM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Yes your front struts are fully extending, i would also check and make sure the upper arm isnt coming in contact with the spring
  3. Apr 19, 2009 at 10:06 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    Well, if your shocks are fully extending over a speed bump, somethin aint right, but I reckon it's a tie rod end
  4. Apr 19, 2009 at 11:38 AM
    trailinTaco
    Bel Air, MD
    whats your setup in the front? do you have longer struts?
  5. Apr 19, 2009 at 3:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. Also check to make sure the Ball joint is not contacting the ends of the cup in which it sits.
  6. Apr 19, 2009 at 3:44 PM
    trailinTaco
    Bel Air, MD
    it may help to say that its such a hard thump that you can feel it like as if you were going over a large pot hole.
  7. Apr 19, 2009 at 4:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your topping out your shocks. This could lead to the breaking.
  8. Apr 19, 2009 at 6:59 PM
    trailinTaco
    Bel Air, MD
    ok thanks ill have to look into new struts. id really like to get coil overs but they cost way too much.
  9. Apr 19, 2009 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should really consider new springs. OME makes a nice lift spring and combined with some Bilstien 5100 shocks, the ride will be much more improved.
  10. Apr 19, 2009 at 8:08 PM
    trailinTaco
    Bel Air, MD
    so your saying that toyota makes a set of lift springs? and im looking and i cant seem to find 5100 front struts. i see rear shocks but not the front
  11. Apr 19, 2009 at 8:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OME = Old Man Emu,
    Tacomaman06 is running that set up on his truck. He should have the info on where to get the parts.
  12. Apr 19, 2009 at 9:56 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Im running king coilovers in front, If you want to go cheap C/O I would check craigslist, get some used coil overs for cheap
