Thump when I stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mrgoody86, Apr 22, 2009.
  1. Apr 22, 2009 at 2:11 AM
    Mrgoody86
    Mrgoody86 [OP] Well-Known Member
    Alex
    Lincoln, CA
    2009 Tacoma 4x4, DBL Cab, Sport Edition
    K&N CAI, Custom duel exhaust with jones muffler, Viper Alarm w/ remote start, Cobra radar detector hard wired and mounted above rear view mirror. Leather Arm rest mod, LED cabin light, Redline elite hood struts. Bilstien 5100's all around, front coilover set at 2.5", Toytec aal, and Total Chaos UCA's, Scangauge II, Front Diff Drop kit, Yellow Lamin-X fog light covers, 6K HID conversion Kit for Headlights
    on my 09 DBL cab LB I have noticed when I stop there is a noise and feeling in the rear end like the rear end is catching up and stopping kinda like when your hauling a trailer when you stop, it sounds more like a thump. I dont have anything done to my suspension yet. and was just wonder if any of you guys have heard of this or seen it for yourselves, maybe a rear brake thing????? just a wild guess though. Sorry if it doesnt make sense its really hard to explain.
  2. Apr 22, 2009 at 3:28 AM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Take a look at post #9 here. I have experienced the same bump. I noticed that when my truck has weight in the back, it doesn't happen. Possibly something to do with less up/down movement and less movement in the driveshaft when the truck comes to a stop. Mine's an '09 access cab 4x4. That post may or may not help, but it is worth a look.
  3. Apr 22, 2009 at 3:57 AM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    My 09 DC 6MT is quiet.
  4. Apr 22, 2009 at 4:09 AM
    dalesrn
    dalesrn Tacoma TSS
    Dale
    Southeast Louisiana
    2008 Tacoma PreRunner DC with TSS Package
    Borla exhaust system, Sirius Satellite Radio, Chrome package, Trailer Hitch, Clazzio Leather seat covers, TSS badging, Anytime on fog lights mod, Daytime driving lights mod, Dual backseat DVD players w/monitors, 3rd Brake Light "TSS" mod, Bed pocket lights mod, Seat belt chime mod, Bed storage compartment auxillary outlet mod, Shorty antenna, Armor Lid Tonneau Cover, Line of Fire tailgate light
    Do you tow a trailer a lot?
  5. Apr 22, 2009 at 4:10 AM
    Mrgoody86
    Alex
    Lincoln, CA
    never.....
  6. Apr 22, 2009 at 5:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its axel wrap. Pretty common on our trucks with automatics.
  7. Apr 22, 2009 at 6:58 AM
    stormyday
    stormyday Well-Known Member
    Morganton, NC
    14 Taco Double Cab Pre-Runner
    Could it be the fuel tank slosh?
  8. Apr 22, 2009 at 6:58 AM
    dalesrn
    dalesrn Tacoma TSS
    Dale
    Southeast Louisiana
    I am not mechanically inclined, but am trying to learn. What is "axel wrap?"
  9. Apr 22, 2009 at 7:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Axel wrap is the springs remaining "preloaded" after comming to a stop, due to the auto tranny sending power to the axel. Once at a stop, being as the brakes are applied, the rear axel is "stuck" in an pinion up position due to the torque. The springs twist a little bit under this torque. When the brakes are released, the axel returns to its normal position, resulting in a "Thump" sound. Many times it can be felt. This is amplified by the length and soft spring rate of the Tacoma rear springs. Some people have fixed this with liberal amounts of grease applied in the slip yolk of the drive shaft (I have not tried this myself, and Im not sure its a good idea), or the use of an AAL.
  10. Apr 22, 2009 at 7:34 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    you might want to check and see if your getting a leak at where the driveshaft enters the transmission.. i have the same "bump or clunk" and i have had a leak at my transmission i feel is caused be that noise...IMHO
  11. Apr 22, 2009 at 7:36 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    yep
    And/or what he said :D
  12. Apr 22, 2009 at 7:45 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I started hearing that noise after I had the Spring TSB done. I have a manual transmission.
  13. Apr 22, 2009 at 8:25 AM
    glennv
    glennv Well-Known Member
    My Cherokee did this so I pulled the rear drive shaft and packed the yoke with anti seize . Solved the problem. I'm new to the Tacoma so I'm not sure of the drive shaft setup. If it does have a yoke I would try that.
  14. Apr 22, 2009 at 1:49 PM
    richard botello
    richard botello New Member
    san jacinto, CA
    07 Prerunner
    running boards, chrome accents on doors,tailgate, push bar chrome inserts on front
    I'm having the same problem......I drive an '07 Prerunner Double Cab..... when I stop and release the brake it seems as though the transmission or rear brakes thump. Maybe the rear calipers? Any ideas?
  15. Apr 22, 2009 at 2:16 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Same here 07 prerunner double cab with TSB done in the rear. I get the same thump when I back up then move forward or take off from a stop. Not always it every now and then.
  16. Apr 22, 2009 at 2:29 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    what he said.. :thumbsup:
  17. May 2, 2009 at 2:59 PM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    my 06 DC 4x4 sr5 does this also but only when the A/C ison, go figure... more torque going to the axel when A/C is on maybe.. no idea.....
  18. Oct 28, 2009 at 12:23 PM
    dustin81
    dustin81 DUSTOFF
    Rio Rancho, NM
    09 TaCo Lifted TRD
    PRO COMP 6" Lift Stage II PRO COMP 2.75" Coilovers PRO COMP MX-6 shocks PRO COMP skid plate Bushwacker Fender Flares Smittybuilt Chrome Steps KC Chrome 6" SLIMLITES Billet Custom Grill JDM window vent visors Window Tint Flowmaster TRD CAI
    same issue, im glad im not the only one. i have a single rear drive shaft that was put on when the lift was put on. I bought the truck lifted with only 800 miles on it, and im just rolling over 11k. and this thump hasnt always been there and started about a month ago and is getting worse...
