Thumping in rear over 70mph?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoEngineer41, Dec 20, 2023.
  1. Dec 20, 2023 at 3:40 PM
    TacoEngineer41
    TacoEngineer41 [OP] Lighting Test Engineer (3rd Party Lab)
    Northern & Central NY
    2018 Tacoma TRD Sport 4x4
    Has anyone experienced softer thump noises going upwards of 70 to 80mph on FLAT highway roads? It almost sounds as if something is shifting around, but I can’t pinpoint where it is coming from. It’s an '18 sport with 97K miles and clean. Does not happen at slower speeds, over bumps, when turning, etc.
    I have tried:
    -making sure the seat belt isn’t hitting plastic
    -making sure nothing is shifting behind or underneath seats
    -making sure the seats/backs are locked in place
    -checking the shocks, leafs, etc. it also doesn’t do this at low speeds or over bumps so I ruled that out
    -checking for loose bolts, nuts, screws, underneath
    -took out a trailer hitch that had some clearance between the walls in case it was that rattling
    -closed the tailgate HARD!
    -made sure nothing is in the bed
    -among other dumb things
    Now I’m wondering as I type this if it’s maybe the tonneau cover. It just started to get really cold here and maybe it needs to be tightened? (Thinking out loud here)
    I personally don’t think it’s anything serious as it only does it at faster speeds and is not constant, but this is driving me nuts. I don’t feel like heading to the shop and having them look at me as if I’m nuts so I thought I’d try here first. If anyone else has experienced this let me know!
  2. Dec 20, 2023 at 3:56 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Check the weather stripping on the roof where a roof rack would go.
    Chew likes this.
  3. Dec 20, 2023 at 4:52 PM
    TacoEngineer41
    all in check! thanks for the recommendation
  4. Dec 20, 2023 at 5:01 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Is it a sport special feature? :crapstorm:
    Make sure the Spare tire is snug. Check that the chain is not long enough to catch air and hit the spare's rim?
  5. Dec 20, 2023 at 5:03 PM
    Al Hoff
    Al Hoff Well-Known Member
    Grand Rapids, MI
    2018 Tacoma Off-Road QUICKSAND
    I had a screw driver rolling around in my glovebox that annoyed me for a little while until I found it. It was muffled enough that it sounded like it came from outside the cab.
    Check the spare tire if you have maybe it needs to be tightened up? I think there is a heat shield around the spare as well, check that for sturdiness? Maybe push around on the gas tank skid and gas tank itself? Are the plastic locking push pins in the top of the rear wheel wells? I’m sure you’ve looked around lol
  6. Dec 20, 2023 at 5:04 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Check the spare tire ?
    2022mgmtrdsport and wilcam47 like this.
  7. Dec 20, 2023 at 5:06 PM
    TacoEngineer41
    Thanks everyone. I haven’t checked the spare or even thought about that. I’ll try that out. Much appreciated.
  8. Dec 20, 2023 at 5:16 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Slow down. It’ll go away..
  9. Dec 20, 2023 at 5:25 PM
    TacoEngineer41
    I've been turning up the music. Same thing I guess lol.
    Greg-tacoma[QUOTED] likes this.
  10. Dec 20, 2023 at 6:03 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    If you go faster than 80 mph and then slow back down, does it occur again as you pass through through the 80-70 mph band?
  11. Dec 21, 2023 at 3:03 AM
    TacoEngineer41
    Ya it’s pretty random. No cadence at all. I just know it doesn’t happen under 70.
  12. Dec 21, 2023 at 5:47 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Betting as you mentioned tonneau cover.
  13. Dec 21, 2023 at 7:40 PM
    TacoEngineer41
    Just tightened everything up, still does it. Now I’m moving on to the spare and checking those heat shields!
  14. Dec 21, 2023 at 7:45 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    The actual term escapes me, but cabin vents behind the back seats?
  15. Dec 21, 2023 at 7:54 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Not sure but my 2001 LX470 (land cruiser) makes zero noise at any speed, 235k miles. I swear these third gen Tacomas are plagued and I won't ever agree otherwise. Toyota themselves have admitted their older vehicles were better built.
    I have faith in the 4th gen Tacoma for some reason though.
  16. Dec 21, 2023 at 7:58 PM
    TacoEngineer41
    interesting thought. Doesn't hurt to check lol
  17. Dec 22, 2023 at 4:49 AM
    timkins42
    timkins42 Well-Known Member
    Tim
    Fishers, NY
    2021 Black Tacoma 4X4 TRD Sport Access cab
    None so far
    The Tonneau cover on mine starts to flap even though it is locked down tight.
  18. Dec 22, 2023 at 5:35 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Tsk tsk, you have a ghost tapping the tonneau cover in the back, trying to tell you to slow down...
    Ghost was like "Ahhh.. that's too fast!" [tapping madly on the cover] while holding onto the truck.
    Which is why you can't find the problem around the truck.
    /shrug
  19. Dec 22, 2023 at 5:47 AM
    TacoEngineer41
    I mean, my first thought was that it definitely sounded like someone was trapped in the bed and trying to get out… haha
    TAZMINATOR[QUOTED] likes this.
  20. Dec 22, 2023 at 7:10 AM
    timkins42
    Tim
    Fishers, NY
    None so far
    Thats where the Elf on the Shelf is hiding.Happy Holidays
    TacoEngineer41[OP] likes this.
