Thumping noise coming from rear of my 06 TRD Offraod 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 99YOTA412, Dec 22, 2011.
  1. Dec 22, 2011 at 6:34 PM
    99YOTA412
    99YOTA412 [OP] Active Member
    layton
    south carolina
    06 Tacoma TRD Offroad, Bilstein 5100 shocks
    hey, when i hit a bump with the passenger side rear tire i hear a thump. like something hitting something. i jumped in the bed and heard it too. and also when i hit a bump sometimes my rear end will jump and bounce a little. any ideas?
  2. Dec 22, 2011 at 6:41 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Maybe the shock mounts are loose?
  3. Dec 22, 2011 at 6:46 PM
    99YOTA412
    layton
    south carolina
    how would i go about fixing that
  4. Dec 22, 2011 at 7:23 PM
    NelsonTacoma
    Tucson, AZ
  5. Dec 22, 2011 at 9:02 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Check all bolts in the suspension. Possibly a bad shock, maybe a loose rear wheel bearing. Jack up the rear wheels and give the tires a shake to check for play in the wheel bearings. I had one make a rattling noise on bumps. It also had a roaring sound that got louder with speed. It sounded kind of like mud tires. If you have loud exhaust or aggressive tires you might not notice the roaring noise from a failing bearing.
  6. Dec 22, 2011 at 9:14 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Make sure your spare tire is tight too. I had one wiggle loose on my dodge and it would clunk around.
  7. Dec 23, 2011 at 3:10 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Get underneath your truck while a friend bounces it up and down to replicate the sound. Repeat until you find the source. It could literally be a 100 different things. Not easily diagnosed on an online forum.
