Thumping noise when coming to a stop!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by agonzalez2003, Mar 26, 2024.
  1. Mar 26, 2024 at 11:50 AM
    agonzalez2003
    agonzalez2003 [OP] Member
    2017 Tacoma TRD Sport RWD
    Hey Guys!,
    I am new to this site, not sure how it works. I have a 2017 Tacoma Sport rwd with roughly 63000 miles. I have ran into a problem where when I am driving and I am coming to a stop, when I'm braking and the truck is downshifting(lowers the rpms) I hear a noise change(from the engine I assume) and then I feel a thump its around 5-0mph. I feel it in the back but not sure if it's either transmission or engine. This happens to me 70% of the time. I only use this truck to commute from my house to work. Not sure if this is common for others or if it's an issue?
  2. Mar 26, 2024 at 11:54 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Make sure your u bolts are torqued to 85ft lb.
    Drive around some.. noise gone?
    If not then it's probably axle wrap
  3. Mar 26, 2024 at 1:45 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If it’s more of a click than a thump, you could be hearing the brake shoes shifting in their mount. If so, you can safely ignore it, albeit people have found ways to secure them better. An internet search should give you results.
    TBQH, a majority of the weird noises people report can be safely ignored.
    tcjacado likes this.
  4. Mar 26, 2024 at 1:51 PM
    G007
    G007 Well-Known Member
    Gary
    Vancouver, Canada
    2023 Tacoma Premium Lunar Rock
    275 70 17 KO2 on 17" Bronze TRD Wheels AFE Intake Magnaflow Exhaust OEM TRD Pro Grill
    gas in the tank splashing around?
  5. Mar 26, 2024 at 3:08 PM
    agonzalez2003
    No, it's not gas, I'll look into the u bolts first, I originally thought it could be something with the axle but I want to make sure it's not something else
  6. Mar 26, 2024 at 3:11 PM
    agonzalez2003
    its a thump, I feel the truck it not just the noise, which concerns me. PS is their a way to reply to yall or its just a post with a quote like what I did right now?
  7. Mar 26, 2024 at 3:14 PM
    pp2small
    pp2small Well-Known Member
    Brian
    Socal
    2022 TRD Offroad
    is your truck stock? Could be something lose in your suspension.
  8. Mar 26, 2024 at 4:27 PM
    Crobran
    Crobran Well-Known Member
    Texas
    `21 DCSB 2.7L Silver Sky
    Trifecta 2.0, Ionic Nerf Bars, Tailgate anti theft device from @christian06, Husky Weatherbeaters, Bed lights, OEM bed mat, Derped badges and grille bezel
    I also get something like this, though not 70% of the time. Probably more like 5%. It's a quiet but definitely noticeable thump that comes from the back, and I can just feel it in the floor when it happens. I notice it when I've come to a slow stop and then slowly start accelerating again. I feel like I've also had it happen when I move from reverse to forward. It's never with aggressive acceleration, only when gentle, easy acceleration or stopping.
    Please update once you've got your u-bolts torqued. I may just go out there and see what the torque is on mine just for fun.
  9. Mar 26, 2024 at 4:40 PM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Just for the heck of it, check you storage compartments behind the rear seats.
  10. Mar 26, 2024 at 4:51 PM
    agonzalez2003
    Its stock
  11. Mar 26, 2024 at 4:53 PM
    gudujarlson
    Minnesota
    I agree. A thump upon stopping is probably a loose object in storage.
    CherylJane likes this.
  12. Mar 26, 2024 at 5:12 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Half empty bottle of bourbon rolling under the seat. Or half full depending on how you look at it.
    Seriously though something is loose and moving.
  13. Mar 26, 2024 at 10:37 PM
    agonzalez2003
    I initially thought it was the tow hitch and removed it, still makes the noise. I have nothing in the truck or in the storage where the bed is, I removed my bat from the back of the seats, and still makes the noise, put that back in its place lol
  14. Mar 26, 2024 at 11:04 PM
    El Reymono
    El Reymono Well-Known Member
    Raymond
    East Providence, Rhode Island
    2010 2.7 regular cab manual Tacoma
    check the strapping holding the gas tank. those can rust and are a common replacement item.
    inwood customs likes this.
  15. Mar 27, 2024 at 2:28 AM
    boi951
    boi951 Well-Known Member
    Boo
    Galveston Island, Republic of Texas
    2020 SR5 2.7 2WD 2009 OR................. 2006 AC.................
    Spare tire?
  16. Mar 27, 2024 at 3:16 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Drive shaft slip yoke needs lube
  17. Mar 27, 2024 at 5:59 AM
    545
    545 Well-Known Member
    2015 Access Cab
    This is my guess as long as you have ruled out loose objects
    faawrenchbndr[QUOTED] likes this.
  18. Mar 27, 2024 at 9:03 AM
    inwood customs
    Dave
    2wd or 4x4?
    2wd have no zerks fittings
  19. Mar 27, 2024 at 9:09 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Read this thread……
    https://www.tacomaworld.com/threads/greasing-slip-joint-boot.357521/
    Use a zip tie to replace the clamp
  20. Mar 27, 2024 at 9:12 AM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    It’s the downshift clunk I bet. Shitty transmission programming combined with some driveline slop. Mines done it since new. Every stop. Feels like I’m being rear ended sometimes. Dealer says normal in my 6-8 visits.
