thumping sound coming from engine bay when at a stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by tsab916, Aug 24, 2010.
  1. Aug 24, 2010 at 12:51 AM
    tsab916
    tsab916 [OP] Well-Known Member
    Sacramento
    02 DC 4x4
    wells i researched a little bit a found out a little bit but wanted your guys opinion..
    this is for a 2002 double cab 4x4 by the way, no locking rear diff if that makes a difference...
    when truck is in park or neutral, there is very very very small thumping sound coming from what sounds like the passenger side firewall inside the engine bay. (sounds like when you turn a bucket upside down and tap on it)
    when you put a load on it ex: reverse or drive, the thumping sound gets louder.
    then if you turn the a/c on while in reverse or drive the thumping sound gets even louder...not super loud, but you can notice that it does get a little bit louder.
    i've search and one thread came up with the same problem and they told him/her to lube the drive shafts and components and to also check the rear brakes for some kind of leak? don't know how that has anything to do with the thump but i guess...
    and i don't think that this is the infamous axle wrap thump that keeps popping up when i search, this thumping sound goes with the idle of the car, like if i listen carefully the thumping noise well thump faster when i rev up, and thump slow at idle.
    so any input guys? it's really starting to bug me....
    thanks in advance
  2. Aug 24, 2010 at 1:05 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Loose exhaust some where some how. It's making contact somewhere.
  3. Aug 24, 2010 at 10:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Check the condition of your fan belts and pulleys. Sounds like you are looking for something related to engine RPMs,
  4. Aug 24, 2010 at 10:17 PM
    tsab916
    Sacramento
    02 DC 4x4
    yea...i just bought the truck used also, and it doesn't look like they have changed the belts...
  5. Aug 29, 2013 at 6:52 PM
    mc3404
    mc3404 Well-Known Member
    Concord ,NC
    03 v6 tacoma
    Did you ever come up with anything?
  6. Aug 29, 2013 at 10:38 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Flywheel maybe? Sounds like there's a few threads on this sort of noise recently.
  7. Sep 8, 2013 at 12:48 PM
    mc3404
    Concord ,NC
    03 v6 tacoma
    To the OP. Any updates? Have you changed your timing belt or te idler pulleys?
