Thunder's Garage Tetris: 04 Taco + 12 CTS-V + 06 GSXR
Discussion in '1st Gen. Builds (1995-2004)' started by ThunderOne, Jun 1, 2015.
  1. Nov 16, 2020 at 2:29 PM
    #401
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    That's my other option. I'm not ready to swap yet, going to do it with my next timing belt change.
  2. Nov 16, 2020 at 3:24 PM
    #402
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
  3. Nov 16, 2020 at 11:09 PM
    #403
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  4. Nov 17, 2020 at 7:46 PM
    #404
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    My truck stays nice and cool with the AC on full blast, and wheeling in 90*+ heat and humidity. I have the smallest tacoma radiator you can get cooling my 3.4, stock fan and half a shroud. I've been happy with it so far. If the 5vz was overheating your radiator or fan clutch was bad, my truck for really hot a few times and it was the fan clutch and the radiator was almost totally clogged with mud and crap. I have like everything under the sun blocking airflow, steering cooler, winch, winch control box, shitty bumper, skid plate etc...
  5. Nov 18, 2020 at 6:35 AM
    #405
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    All 3 of my 5vz trucks have overheated before, but they're also automatics. I'm assuming that plays a factor since trans fluid adds heat to the radiator. My third gen overheated on the first wheeling trip out when it was sparkling clean, just running the AC on a steep dirt road. Wife's third gen overheated around town one day a year ago, then never again. My tacoma would overheat plenty, but when I replaced the radiator that was very clearly the problem lol. Still hit 230 degrees trying to drive up the insanely steep road at windrock though.
    3rz never gets above 190, it's really nice. Manual truck and all metal radiator though.
  6. Nov 18, 2020 at 7:02 AM
    #406
    slander
    Hickory, NC
    Wow that's crazy, something's not right with all that. I have a denso plastic stock single core tiny radiator with no issues with my AC on full blast all the time because I'm a pussy when it comes to heat and humidity, weird. The fan clutch was working in all those situations? Mine hit like 230 and you could freely spin the fan, replaced the clutch and it was gtg.
    Justinogo[QUOTED] likes this.
  7. Nov 18, 2020 at 7:05 AM
    #407
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Fan was going every time. I think the auto trans just pumps that much heat
    slander[QUOTED] likes this.
  8. Nov 18, 2020 at 7:18 AM
    #408
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    John’s 4Runner uses a 3VZ radiator with the 5VZ swapped auto and no overheating. The 3VZ rad is like 4-5 inches smaller in all directions compared to a 5VZ rad too
  9. Nov 18, 2020 at 7:25 AM
    #409
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Now that's pretty interesting. No issues in Moab 2 years ago?
  10. Nov 18, 2020 at 7:26 AM
    #410
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Nope, we were all boiling fuel in the tank but no overheating
  11. Dec 14, 2020 at 11:31 AM
    #411
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  12. Dec 29, 2020 at 9:40 AM
    #412
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    List of shit I need to do:
    -Fix this damn rattle right next to my left ear that occurs at mid-range bass frequencies
    -Remove a leaf from each leaf pack, clean/repaint/reline leaf packs
    -Cut off old LCAs, Install new LCAs
    -Remove passenger side quarter panel to find this awful rustling at speed rattle I've been listening to for years
    -Remove driver side quarter panel and straighten it because LBJ failure from 8 years ago lulz
    -Paint gap filler piece under headlight to match new plastidip job
    -Paint new center caps and install
    -Drill new hole for oil drain plug on skid after welding a patch plate in place
    EDIT: fix horn (probably a bad ground.. again...)
    Phessor likes this.
  13. Dec 29, 2020 at 10:41 AM
    #413
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Get busy!
  14. Dec 30, 2020 at 11:24 AM
    #414
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I think I'll start with the rattling stuff first lol
    Phessor[QUOTED] likes this.
  15. Jan 3, 2021 at 9:34 PM
    #415
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I'd rather do the suspension work. I hate dealing with interior plastic panels. Plastic is much less forgiving than metal is lol
  16. Jan 4, 2021 at 12:56 PM
    #416
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've taken apart the interior plastics so many times I could do it with my eyes closed lol. I even replaced some of the clips with actual screws into plastic sleeves so it would be easier to remove the next time.
  17. Jan 13, 2021 at 7:56 PM
    #417
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Taco got kicked out of the garage for now, at least until my roommate moves out and there's no longer two motorcycles in the garage.
    New member of the family.
  18. Jan 15, 2021 at 9:32 PM
    #418
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Got this one done, turned out one of the fender liner clips broke and was rattling around all over the place in the wind, between the fender liner and the front of the passenger side door. No more rattle now! So much quieter on the highway.
    But I forgot to add -fix horn to my list. Can't keep the goddamn things grounded and one always goes out. "Meep meep" I honk, as I try to convey anger towards nearby drivers. :facepalm:
  19. Jan 17, 2021 at 6:58 PM
    #419
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Pics in this parking garage are always :headbang:
    BYJOSHCOOK and betterbuckleup like this.
  20. Jan 17, 2021 at 9:48 PM
    #420
    betterbuckleup
    Ian
    Concord, CA
    Hell yea man. Jealous of that V.
    I love those cars and have always wanted one. Especially a wagon.
