"Thunk" disengaging 4Hi?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jandrews, Jun 27, 2009.
  1. Jun 27, 2009 at 8:04 PM
    jandrews
    jandrews [OP] Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Hi all.
    Took the new Taco out on some dirt trails on my folk's property today to play a little in 4Hi. Truck did beautifully. When I got back to their gravel drive and switched back to 2Hi, I noticed an audible "thunk" from the front end of the tranny...is this normal? The dash icons seemed to indicate that everything went into and out of 4x4 normally (per the descriptions in the owner's manual). Nothing in the OM about a "clunk" when disengaging though.
    Before anyone asks:
    - No I have not been playing around in 4x4 on dry pavement/gravel.
    - Yes the vehicle was completely stopped and the shifter was in neutral. Yes, I know this isn't necessary for 4Hi, but happened to be stopped anyway, so why not?
    Thanks in advance. Performance in 2Hi seems fine. Don't think I killed anything in the driveline...
  2. Jun 27, 2009 at 8:27 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    the thud is from it disengaging normally. mine has done it every time
  3. Jun 27, 2009 at 8:30 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I experienced the same thing a couple of weeks ago. I engaged and disengaged 4hi a few times in a row, and each time the clunk occurred. Just assumed it was Fine, after all it is a mechanical system. That said, when I had used 4hi this past winter I didn't really have the same issue.
  4. Jun 27, 2009 at 9:03 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Yup, normal. The clunk is worse if your wheels are turned when you disengage. I try to straighten my wheels before I disengage for this reason.
  5. Jun 27, 2009 at 9:10 PM
    SilverStreakUSMC
    SilverStreakUSMC Member
    Charlottesville, VA
    it happens randomly, but ive noticed it more if im either going TOO fast, or i try to take off too fast from neutral, when you shift back into gear, it will say that its off, but you need to ease it back into driving. but as far as i can tell its no damage. everythings normal.
  6. Jun 27, 2009 at 9:49 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    never been able to avoid the clunk here, no matter what I do.
  7. Jun 28, 2009 at 2:08 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I been putting my truck in neutral and then taking off 4hi. It seemed to make the clunk very small and not noticable. I got this from Toyota Nation so I can't take credit. It does seem to help
  8. Jun 28, 2009 at 5:01 AM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Mine does it too...
  9. Jun 28, 2009 at 5:09 AM
    Brunes
    Brunes abides.
    Rotorhead
    It's no big deal...Gears meshing and un-meshing....As long as you follow the rules on the OM about speeds and stuff you'll be fine. As the gears get settled and wear into each other it may get quieter as well.
  10. Jun 29, 2009 at 1:13 PM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    Sometimes mine does it, sometimes it doesn't. Given the amount of steel turning when it is using the front wheels, I'm calling it normal. :)
