Thunking DRIVIN ME NUTS!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cheesycook, May 14, 2012.
  1. May 14, 2012 at 11:36 AM
    Cheesycook
    Cheesycook [OP] Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Okay guys, I am stumped. My rig is an 01 DC, 6Cylinder, AUTO, TRD Offroad 4x4. Almost 8 months ago I installed a ToyTec ~3.5" lift with new upper control arms, Bilstein 5100 shocks, and new OME leaf packs. I have been very happy with the setup and my pickup as a whole. However, I live in a rural area and have a recent thumping in the back that started out of nowhere and is driving me absolutely crazy. It sounds like it is coming from the rear and is definitely metal on metal. It doesn't really reverberate through the cab like bottoming out or anything. I can feel a slight vibration in my seat. It is exaggerated on speed bumps or off cantor drives that wobble the rig back and forth but also comes about with both wheels compressing at the same time but it has to be something like a speed bump to get it. A
    At first I was certain it was my exhaust hitting my leaf spring but I put some clay on the spring and reproduced the sound without any sign of the clay being disturbed. I greased all my fittings, snugged up all the nuts and bolts I could find. I checked the spare tire, exhaust, heat shields, skid plates, canopy connections, trailer hitch, spring packs, lugs........ Nothing! I can't find anything causing this and cannot reproduce the sound standing on either side of the rear bumper jumping my 215 pound butt up and down rocking the truck for all it is worth.
    Any off the wall ideas, boneheaded things I should check, or possible suspension issues that could cause this? Thanks in advance guys. My job is ending, three kids, and the wife just got diagnosed with MS. Getting this fixed would help alleviate the weight on my shoulders.
  2. May 14, 2012 at 11:45 AM
    dan476
    dan476 Well-Known Member
    have you checked your u-bolts?
  3. May 14, 2012 at 1:23 PM
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Yeah, I got maybe a single turn on half of them. Nothing that would have allowed for movement.
  4. May 14, 2012 at 1:46 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Shock bolts good and tight?
  5. May 14, 2012 at 1:51 PM
    TacoBran
    TacoBran You're Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    2023 Double Cab Trail Edition; 03 Double Cab 4x4 TRD SOLD
    2023 Bone stock... 2003 - Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs - 4x4 swap in progress
    carrier bearing shot?
  6. May 14, 2012 at 1:56 PM
    AbsolutPolack
    AbsolutPolack Member
    Central MA
    2011 Stock DCSB 6spd
    Not sure if the 01's have the compartments in the bed like my 11 does but I store ratchet straps in them and it clunks. maybe you have something like that stored and kicking around. somewhere.
  7. May 14, 2012 at 1:58 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Axle wrap? does it get worse the harder you floor it on starts?
  8. May 14, 2012 at 2:22 PM
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Shock bolts are tight.
    No compartments, used to think the thunking was all the tactical entry tools and coffee maker, but that's all out. Totally emptied and stripped.
    Doesn't feel like axle wrap, plus I got the seven spring leaf's with no blocks. No feel of preload when taking off. Used to have serious wrap on my old mustang with stock springs.
    How do I diagnose the carrier bearings? I get almost no vibration or noise driving at almost any speed.
  9. May 14, 2012 at 5:24 PM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Check you sway bar links, I disconnected my links when I was installing my lift, and didn't snug them up enough, took a little while for them to loosen up too...
    Kind of a pain to do with all the gunk on them, but, you need a socket and a hex head.
  10. May 14, 2012 at 10:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You have a 3.5" front lift? I've been told from sources all over that 3" is THE absolute limit for IFS . Anything over requires drop bracket, & I tend to believe that only half an inch over is enough to cause all kinds of hell
  11. May 15, 2012 at 7:01 AM
    TacoBran
    Brandon
    Peoria, AZ
    Also sorry to hear about your wife.
    Is it a loud thunk?
    Loose lug nuts?
    Bed liner bouncing around?
    Do you have an add a leaf, blocks, or new springs in the rear? Could something be loose here?
    Shackles are all torqued to spec?
    Is the noise when your tires first hit the bump or more when the weight is off the truck at the top of the bump? Basically when the suspension is compressing or releasing?
  12. May 15, 2012 at 7:56 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Bad body mount, or rear motor mount, maybe?
  13. May 15, 2012 at 9:57 AM
    Bama_TACO
    Winfield, AL
    Don't completely rule out the front. I spent a ton of money on a roar that I would have bet my left nut was coming from the front of a Suburban I had. After much time and money spent on parts for the front, it turned out to be a bad wheel bearing in the rear.
  14. May 15, 2012 at 3:35 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Check the castle nuts on the outer tie rod ends. That made a very similar noise on my truck. It turned out that they were just loose, so I torqued them back down and reset the pin. No problems since.
  15. May 16, 2012 at 2:02 PM
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    The front lift was not as high as the rear. It was 2.5" from the 5100 adjustable struts. The angle on the front shafts don't look bad at all.
    Is it a loud thunk?
    Sounds like someone dropped a five pound metal weight in the bed of the truck.
    Loose lug nuts?
    Checked those, good.
    Spray on, did snug my canopy down with no change.
    Complete 7 leaf OME replacements. No signs of issues or looseness there.
    Checking this weekend, but they are snug.
    When the truck is compressing / coming down.
    Luckily the family is heading out for the weekend to see Cirque de solei with grandma so I will get some quality time in the garage. Thanks for the suggestions all. I will keep you updated.
  16. May 16, 2012 at 4:05 PM
    TacoBran
    Brandon
    Peoria, AZ
    :eek:
    Did you get new shocks with the lift? Or using the old?
    Maybe one is blown from being over extended?? Really taking a stab in the dark now lol
    Gas tank loose under there?
    Keep us posted would like to know now haha
  17. May 16, 2012 at 4:18 PM
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Muffler was the first thing I thought it was, no dice. It's nice and tight and not hitting the leaf like I figured it was. Shocks are Billy 5100's that went in less than a year ago and seem fine. I did add the gas tank to the list of things to check this weekend. I know the skid is tight but sound didn't change empty tank to a full tank.
  18. May 16, 2012 at 4:19 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    I know with my OME Dakar leaf springs I had to move the axle back about 1 inch to correct how much the leaf springs moved the axle forward. I was bottoming out the slip joint on the drive shaft. I still have a clunk, which i know it's axle wrap and possibly the aft leaf clamp
  19. May 16, 2012 at 4:33 PM
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    I would think that a viable thing except that I haven't had any thunking or issues like this for the past 8 months or so. So I would think we could eliminate bottoming out the slip joint as the axle hasn't moved. If anything it has gotten closer to stock with some slight settling.
    I have gotten the thunk on speed bumps going pretty slow or going as fast as 35 hitting rough patches in the road. I try to take it easy turning now as to not aggravate anything. If I go REALLY slow over speed bumps it doesn't happen. I tried to replicate the sound by jumping on the bumper but I don't think I can equal the down force of the entire rear of the truck dropping an inch or two in a hurry.
  20. May 16, 2012 at 6:21 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    :confused:
    checked the bed bolts? the spare tire is snug?
