Thunking DRIVIN ME NUTS!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cheesycook, May 14, 2012.
  1. May 30, 2012 at 5:14 AM
    #41
    Cheesycook
    Cheesycook [OP] Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    No prob, ten years ago that would have been suspect number one. Snugged all the bed bolts. I do have to wonder about the support goint directly over the wheels hovering rmm off the frame.........couldn't they throw a bolt on there for good measure?
  2. May 30, 2012 at 5:16 AM
    #42
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Davtopgun, excellent idea. I will have to play around with that idea.
  3. May 30, 2012 at 8:48 AM
    #43
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    One other thing I noticed. My u-bolt plate that the shocks are mounted to are not quite level with each other. The passenger side has the bolt ends straight down but the driver side are a few degrees forward. Anybody else like that or is this an issue?
  4. May 30, 2012 at 10:55 AM
    #44
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Is there any audio of this noise ??:notsure:
  5. May 30, 2012 at 10:58 AM
    #45
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    I can see about grabbing a video later..... Just hate letting anyone else drive my baby.
  6. May 30, 2012 at 11:16 AM
    #46
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Strap a video camera to the frame pointing at the rear end, go for a drive.
  7. May 30, 2012 at 5:07 PM
    #47
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well brother ya gotta give us something solid noise wise to go from, & how are spring bushings if this hasn't been addressed.......;)
  8. May 31, 2012 at 7:06 AM
    #48
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This does not set right with me. I would remove the cockeyed ubolt plate and re-install it. Is it possible that the centering pin is not properly situated in the hole of the axle housing?
  9. May 31, 2012 at 7:34 AM
    #49
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Spring bushings appear to be fine. I will add reinstalling the spring perch to this weekend's things to do list.
    Good news though guys. I found an old el cheapo chinese mini surveilance camera my tactical team tried using for training but couldn't because it doesn't do indoor lighting very well. Well, works great in natural light. I JB Welded a high strength magnet to the back of it last night and started getting some different angles on the suspension with audio. Tomorrow when the family takes off I will get some more angles and cut up a video to send your way. I don't know why I wasn't using this before. Cheap and pretty good results.
    This is what I am using: http://www.ebay.com/itm/Mini-Video-...671899?pt=Digital_Cameras&hash=item5630d8571b
    #49
  10. May 31, 2012 at 7:36 AM
    #50
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Oh yeah, the spring center bolt appears to be in place in the axle perch. it sits flush but I will inspect it this weekend.
  11. Jun 1, 2012 at 9:31 PM
    #51
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
  12. Jun 2, 2012 at 2:51 AM
    #52
    Davtopgun
    David
    Central Alabama
    3:20 - 3:23
    Sure looks like the leafs clapping together.
    Do you have two overload leafs in there or am i seeing things?
  13. Jun 2, 2012 at 3:06 AM
    #53
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Wow that video took a lot of work. It's been bugging you that long, three years? I'd be going nuts too! That being said, that is exactly the sound the hook in my hitch makes when I go over bumps too.
    Other than that, when I saw the leaf springs like what was said above, that's the first thing I though of too.
    :notsure:
    Sorry. That's all I got.
  14. Jun 2, 2012 at 7:57 AM
    #54
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    It's only been happening for three or four months. I put the lift on almost a year ago. The leaf is a OME Dakar. Definitely annoying.
  15. Jun 2, 2012 at 7:59 AM
    #55
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Oh yeah, ignore the time stamp. Cant figure out how to change it on this cheap thing.
  16. Jun 2, 2012 at 3:34 PM
    #56
    Davtopgun
    David
    Central Alabama
    And you haven't changed ANYTHING in the drive train or suspension on this truck sense installing the lift almost a year ago?
  17. Jun 2, 2012 at 4:11 PM
    #57
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Not in the drivetrain, too busy at work.
  18. Jun 2, 2012 at 4:42 PM
    #58
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    At about 18 to 30 seconds of the video it looks as if the rear u-joint is hitting the gas tank skid (from the shiny spot of metal on the skid next to the u-joint). Might be a possibility??
  19. Jun 3, 2012 at 12:04 AM
    #59
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    I think I marked that up when I pulled the shaft.
    Does anyone know if the bed support subframe rail directly above the rear wheels are supposed to touch the frame? Mine sits about a millimeter off the frame.
  20. Jun 3, 2012 at 10:04 PM
    #60
    tan4x4
    Rick
    Folsom, CA
    Mine appears to be right on the frame.
