Thunking under hard braking?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RacerP, Jun 2, 2012.
  1. Jun 2, 2012 at 10:09 AM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I know there is another thread going right now, about a thinking, and I have read thru the entire thing, not the same as mine.
    Mine ONLY comes from hard braking in forward or reverse. Moderate to easy braking nothing happens. I can't tell for certain it's coming from the front, but, that's what it sounds like?
    I did new rotors, pads, and calipers, new brake hose up front. Adjusted the rears too. Made double sure everything was snugged up properly.
    I don't think it's my suspension or sway bar, because it doesn't happen over any bumps or turning just hard braking.
    Thoughts??
  2. Jun 2, 2012 at 10:27 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Sounds like axle wrap or a sticking drive shaft slip yoke. Very common to 1st gens.
  3. Jun 2, 2012 at 11:16 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    one thought, and I may be way off base, I don't know how many miles on your truck, but one car I had that after I passed 150,00 miles, the rubber motor and trans mounts were wore out and it was thunking under hard braking.
  4. Jun 2, 2012 at 1:24 PM
    RacerP
    Chicago
    2003 4x4
    Both of those are good suggestions, although pretty certain not axle wrap since I just had the frame replacement done in January with new leafs?
    But, certainly does sound like something "shifting"...
    I suppose I should look at my trans as well, I just noticed I am leaking trans fluid from my trans dipstick at the joint???
  5. Jun 2, 2012 at 2:38 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    wish I could help more, but I am a novice on this.
  6. Jun 7, 2014 at 6:23 AM
    Redtruckgma
    Redtruckgma New Member
    Savannah
    2008 pre runner
    Towing bar and side rails
    When u brake hard the tran fluid is forced to the rear of pan. If fluid level is low, pickup nozzle is not intact with fluid. I just went to tran. specialist, who diag the prob and I'm running fine.
