Tick at Lowe speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyoTRDtaco, Jul 20, 2011.
  1. Jul 20, 2011 at 1:20 PM
    toyoTRDtaco
    toyoTRDtaco [OP] Well-Known Member
    NB, Canada
    2006 Double Cab TRD Sport
    Ive been noticing lately a tick coming from the drivers rear over the last few weeks on my 06 taco. I took the truck into a shop last night to rotate the tires. I noticed that when spinning the drivers side rear wheel one full revolution there is 1 single tick coming from inside the axle. I'm not sure if I need a whole neww hub assembly or just the axle bearing.
    Any help would be great.
  2. Jul 20, 2011 at 3:14 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    At Home Depot but never at Lowes. :)
    Lift the tire off the ground, put it in neutral, and spin the wheel. If the sound appears take the wheel off and spin the drum. If it quits then it may be something like a TPMS sensor part banging around in your tire (2010+ models). Remove the drum and see if there is a rock or other loose object in the assembly. Spin the axle without the drum and see if it happens. You might be able to pin-point exactly where the sound is coming from.
  3. Jul 20, 2011 at 3:16 PM
    PineappleGrenade
    PineappleGrenade Well-Known Member
    Zach
    Ohio
    '13 Honda Accord Sport
    lol, I thought it was Rob Lowe!
  4. Jul 21, 2011 at 2:43 AM
    toyoTRDtaco
    NB, Canada
    I have taken the wheel off and I did spin the hub. It still ticks once every revolution. I don't want to buy a hub assembly if all i need is an axle bearing. Know what I mean?
  5. Jul 21, 2011 at 3:00 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    haha, for a second I thought this was about ticks at the lowes store... I was like whaaa?
  6. Jul 22, 2011 at 12:07 PM
    toyoTRDtaco
    NB, Canada
    So I ordered a new hub assembly. $300 later and hopefully that will take care of the tick.
  7. Jul 22, 2011 at 12:21 PM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Take the wheel off and see if there is a high spot or something that hits the splash guard as it rotates.
    You can just bend the splash guard back slightly and it should stop.
  8. Jul 23, 2011 at 5:46 AM
    toyoTRDtaco
    NB, Canada
    Ive tried that, no dice.
  9. Jul 23, 2011 at 5:53 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    "If it's not broke, don't fix it"
    I wouldn't worry about it unless it starts giving you problems.
