Ticking and deep knocking noises
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyTaco619, Mar 19, 2015.
  1. Mar 19, 2015 at 5:29 PM
    ToyTaco619
    ToyTaco619 [OP] Member
    2010 Toyota Tacoma DBL Cab Pre-Runner SR5
    so i got a 2010 DCLB tacoma. it has 76000 miles on it. I just did and oil change with 5w30 synthetic Mobil1, and after i did the oil change. a week later i started to hear ticking from under the hood. which is a constant ticking sound, and then under the truck i hear a deep knocking noise. can someone please help me fix this issue. ill try and upload the video so you guys can see what im talking about. THANKS TACO FAM!
    heres the link to the YouTube clip, it wont let me upload here for some reason.
    https://www.youtube.com/watch?v=i3gewXuBt3A&feature=youtu.be
  2. Mar 19, 2015 at 5:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Kinda sounds like an exhaust leak.
  3. Mar 19, 2015 at 7:50 PM
    ToyTaco619
    thanks for the replys guys! hey Chris4x4, if it is an exhaust leak. where is it located to be checked if it is. and is it an expensive fix? sorry if im not making sense.
  4. Mar 19, 2015 at 7:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well....it would be along the exhaust system. I cant tell from your vid. Shouldn't be too bad to fix. However, I would try DoorDings idea first. Go back the the other oil, and see if anything changes.
  5. Mar 19, 2015 at 7:56 PM
    ToyTaco619
    the thing is, i recently purchased this truck not to long ago. and i looked through owners log and couldnt find anywhere what the previous owner used for his oil. so i looked around on forums and they said mobil1 synthetic is my best bet.
  6. Mar 19, 2015 at 7:56 PM
    ToyTaco619
    you think instead of recording with my cell phone, i'll get better quality using my gopro? so you guys can hear both sounds that is coming from under the hood and under the truck?
  7. Mar 19, 2015 at 7:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You put in the correct amount, right? And used the correct weight?
  8. Mar 19, 2015 at 8:04 PM
    ToyTaco619
    i put 5 quarts. it was depicted to use 5 1/2 - 6. but after 5 quarts, i check the dip stick and it a hair below the max line. what do you mean by correct weight. sorry im new to all this mechanics and auto life.
  9. Mar 19, 2015 at 8:18 PM
    ToyTaco619
    yeah i used 5w30 mobil 1 synthetic oil. the ticking sound underneath my hood, i just got done reading that, that sound nearly ever tacoma owner has. but the knocking sound under the truck i haven't heard or read that, thats normal. but i will take it in first thing tomorrow. hopefully there is no charge for just checking it out.
  10. Mar 19, 2015 at 8:40 PM
    ToyTaco619
    awsome! thanks bro!
  11. Mar 19, 2015 at 8:40 PM
    ToyTaco619
    also, if i decide to go back and change oil's. do i have to purchase a brand new oil filter? even though i changed the oil last week?
  12. Mar 19, 2015 at 8:54 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    thats not the normally talked about tacoma tick. Sounds like valves to me. The knock could be any number of things including, but not guaranteed to be, rod or main bearing. The whining could be power steering pump, alternator, or oil pump. This is all just armchair mechanics though as cell phone videos can pick up certain things, miss others, and distort the rest. Did you at any time start the truck while there was no oil in it?
  13. Mar 19, 2015 at 9:12 PM
    ToyTaco619
    no i didn't start the truck while there was no oil. the only time i started it, was when i got done doing the oil change. started it up for a couple mins so the oil can run through the truck. its hard not knowing much about vehicles, because if it is power steering pump, alternator or oil pump. i dont even know where to begin. kind of on a tight budget if i were to take it in to a dealership for something i can hopefully do my self and save money rather then take it to a dealership and spend alot of money.
  14. Mar 19, 2015 at 9:20 PM
    ToyTaco619
    fort sill? im out of the service already. lol im located back home in San Diego
  15. Mar 19, 2015 at 9:29 PM
    2008taco
    chris
    san diego
    Well the steering pump is fairly easy to diagnose. First make sure there is fluid in it. Then while running turn the wheel one way, then the other. The whine will change pitch if it is the pump.
    The big concern is the knock. You could get more help if you can identify it's location. Take a stethoscope, large screwdriver, long extension, or even a broom handle. Put one end against solid metal on the engine and your ear on the other end. Keep moving it to new spots on the engine until you find a spot where the noise is the loudest. This will also work for the power steering pump, alternator, A/C compressor, water pump, etc. Be VERY CAREFUL around running engines though. Make sure you know what is moving, and NEVER reach in blindly.
  16. Mar 19, 2015 at 9:36 PM
    2008taco
    chris
    san diego
    If all else fails you can shoot Speed Freek a message. He is a tech in north county who does a lot of work on people's vehicles. He is a cool guy and will work with you.
  17. Mar 19, 2015 at 9:36 PM
    ToyTaco619
    so in conclusion, what would be the best route to take on trying to figure out these noises?
  18. Mar 19, 2015 at 9:44 PM
    ToyTaco619
    cool thanks bro. so how would i locate this guy speed freak on this site? search him up on the search menu? kinda new to this sorry
  19. Mar 19, 2015 at 9:58 PM
    2008taco
    chris
    san diego
  20. Mar 19, 2015 at 10:07 PM
    ToyTaco619
    thanks 2008taco & doording!
