Ticking in the lifters?
Discussion in 'New Members' started by rhzoflv, May 6, 2011.
  1. May 6, 2011 at 5:26 PM
    rhzoflv
    rhzoflv [OP] New Member
    bobby
    las vegas
    07 tacoma 4 cyl access cab
    Hello I bought a 07 tacoma 4 cyl access cab new. I have been very good about all the required maint. It has 64,000 now and I am noticing a few things I have no clue of why.
    1) Ticking in the motor. sounds like a lifter. is this hard to adjust? is it possible to do myself?
    2) a squeal when first started for about 5 minutes.
    3) it seems to be getting more and more gutless.
    4) it idels rough but has no codes
    Any help please would be appreciated.
    I cant afford another one when this one i still owe on
  2. May 6, 2011 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ticking is normal. You can change the plugs, and see if that smooths out the idle
  3. May 23, 2011 at 8:11 AM
    usadaytrader
    usadaytrader Well-Known Member
    Have you figured it out? I have the same issue that originally occurred about the same mileage as you. I dont have a hesitation problem, just the lifter noise. I cant figure mine out yet. I have replaced 2 out of the 16 hydraulic valve lufters (valve lash adjusters) at $63 a piece! Still makes noise. Let me know if you solve it.
  4. May 23, 2011 at 8:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ticking is normal. These trucks dont use hydraulic lifters. Its a shim under bucket system, and it will always have some sort of ticking. Some vehicles are not as noticable, as more sound dampening is designed into the engine. This is fine on a $40k vehicle, however, costs need to be cut when competing in a $20k price point.
  5. May 23, 2011 at 9:00 AM
    usadaytrader
    Actually I know the 4 cylinder is a hydraulic system. Pre 05 is the bucket system. I know. I changed two of the hydraulic valve lash adjusters yeterday
    jim1234 likes this.
  6. Mar 20, 2016 at 8:57 AM
    jim1234
    jim1234 Active Member
    jim
    pocatello Id.
    2009 tacoma 4 cyl base
    intermitent wiper review mirror Cruise control 4cyl manuel 09
    I smothed out my idle some by simply removing the PCV and cleaning it with spray cleaner then reinstaling. Not hard.
