ticking motor
Discussion in 'Technical Chat' started by easttexasboy, Mar 16, 2010.
  1. Mar 16, 2010 at 8:02 PM
    easttexasboy
    easttexasboy [OP] Active Member
    texas
    02 sr5
    i have a 02 taco. v6. it has a ticking in the engine and i did the screw driver trick and it is coming right from the center of the engine. valves? hopfully nothing serious?
  2. Mar 16, 2010 at 8:07 PM
    JayJay
    JayJay Well-Known Member
    Pacific Northwest
    08'Taco.DC,SR5.TRD. Off Road,Manual 6Spd.
    3 inch lift Rev Tek Bilstien shocks .Westin crome side nerf bars (steps) Toyo 285-16" , HID High/Low 4300k ,yellow fogs 3000k, Lear cap 100 XQ , Thule Tracker 2 roof rack , Bed Rug bed liner ....
    maybe main bearings , that what it is on my 1990 toy4x4 its called the toy tick ... i could be wrong ....... just a thought ....
  3. Mar 16, 2010 at 8:10 PM
    easttexasboy
    texas
    02 sr5
    is that bad? does it need to be fixed? if so is it expensive?
  4. Mar 16, 2010 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    How loud is the ticking?? The engines in the Tacomas are not very well sound dampened. They are noisy. They are known for the ticking, and many things can cause it. A couple examples are the Injectors, and the "Lifters". The Engines use a Shim under Bucket valve adjusment, and they are noisy.
  5. Mar 16, 2010 at 8:28 PM
    easttexasboy
    texas
    02 sr5
    someonelse told me they thought it was the lifters. its not too loud you can here it good when your on the hwy. have to listen for it when idle. gets worse with acceleration.
  6. Mar 16, 2010 at 8:47 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    What oil you running? Is it worse at start up or pretty much stays the same? If the lifters are singing on the highway, then you should be able to hear a pretty good tap at idle.
  7. Mar 16, 2010 at 8:52 PM
    easttexasboy
    texas
    02 sr5
    10w 30 i believe. i can hear it at idle just not as loud as the hwy.
  8. Mar 16, 2010 at 9:20 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    If I missed the mileage, what was it?
  9. Mar 16, 2010 at 9:30 PM
    easttexasboy
    texas
    02 sr5
    it stays the same warmed up or not. the mileage is 156000.
  10. Mar 16, 2010 at 9:37 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    Sounds like the lifters. Please share the screwdriver theory.
  11. Mar 16, 2010 at 9:47 PM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    I had a similar issue with my 05 Tacoma V6. I can hear a ticking/clicking noise that becomes more pronounced under acceleration. I found out that there was a TSB for the 05-06 model's exhaust manifolds. Supposedly some were prone to leaks. I took the truck to the dealership to have them check it out but they said the noise is simply the injectors. I know we have different trucks but another thing you might want to check would be for an exhaust leak caused by a manifold crack. I am no mechanic but thought I would pass the idea along.
  12. Mar 16, 2010 at 9:51 PM
    easttexasboy
    texas
    02 sr5
    using the screwdriver as a stethoscope cuz i dont have one. a guy on the other thread told me to do it to locate the exact location. i have heard of doing that before too but have never done it.
  13. Mar 16, 2010 at 9:54 PM
    easttexasboy
    texas
    02 sr5
    thanks captain. will do. if it is any of these suggestions is it a major problem that needs to be looked at asap?
  14. Mar 17, 2010 at 10:34 AM
    easttexasboy
    texas
    02 sr5
    do i probly need to take it in or...?
  15. Mar 18, 2010 at 3:26 PM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    Its up to you. My truck makes a lot of noise but when I took it to the dealer to have it looked at, I was told it was normal injector noise. If you are seriously concerned, I would take it to get looked at. In my personal opinion its better to look like an idiot in front of a mechanic than to look like an idiot in front of thousands of drivers as you sit stranded on the highway.
    If it seriously concerning you then take it in. I tend to be cautious, especially when it comes to my truck!
  16. Sep 17, 2010 at 1:23 PM
    ctk
    ctk Active Member
    The subject bologna is not directed at you CaptainFun.
    It troubles me that Toyota can call this "normal"!!
    Injectors can make a ticking sound but I think the tick heard in gen 2 Tacoma's it something more. I have a 2011 Tacoma and it the tick really kicks in around 2k rpm and I can even hear it at hwy speeds. It's more pronounced under light acceleration (with a load on the engine).
    Not all Tacoma's do this. The three 2010 v6 I test drove had no tick.
    Mine sounds like an exhaust leak but I'm fairly sure it's valve train noise.
    Why do most claim it's on the left (driver) side?
    I suspect it's a quality control aka poor assembly techniques.
    -OR- may be related to the variable valve timing mechanics?
  17. Sep 17, 2010 at 3:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Toyota doesnt build alot of sound dampening into their engines, as other manufactures do. Being an aluminum engine, its going to transmit noise quite well. Have your truck looked at. Some ticking sounds have been related to an exhaust leak. Otherwise, it could be the VSV, injectors, valve train, etc. In some trucks, the ticking isnt as pronounced, but they all do it.
  18. Sep 18, 2010 at 4:45 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    A main bearing is more like a knock than a ticking sound....and it's very expensive.
