Ticking noise+++ABS BRAKE SYSTEM???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steve1970, Jan 15, 2025.
  1. Jan 15, 2025 at 6:29 AM
    Steve1970
    Steve1970 [OP] New Member
    Hello
    New to the site. we just had a snow event and i ran my truck in 4h for a whole day, snow and ice packed underneath the truck. when i took it out of 4wd, noticed a ticking sound like a stick in spokes. Does not do it all the time, just wandering if it had something to do with the 4wd.Thanks for any advice....Maybe my ABS system???
  2. Jan 15, 2025 at 2:16 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. First thing I'd check if there is/was snow and ice packed all underneath is that there isn't a chunk of ice or something stuck between the wheel and brakes or anything else that spins. Does the sound happen when it turns? Might be a chunk of ice hanging down by the tire and only hits it when you turn. Look at that stuff first because if the only thing that changed was you playing in the snow then that's the simplest explanation. After you rule that out then you can start diagnosing further if it's ABS, 4x4, or something else causing it. Good luck.
  3. Jan 15, 2025 at 10:21 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it tick more when you are turning?
  4. Jan 16, 2025 at 3:49 AM
    Steve1970
    Seems like that is the only time i hear it is when i turn . And its no all the time.
