Ticking NOISE?!?!?! Anyone ELSE?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nammerz, Oct 8, 2012.
  1. Oct 8, 2012 at 4:34 PM
    nammerz
    nammerz [OP] Member
    Marysville, wa
    09 Tacoma DC
    So, I just recently got my tacoma, and I just have a question about it. Usually it would sound like i need a valve adjustment, But i took it into a dealer and they said the injectors were just loud. is this a normal thing with tacomas? I don't want them to be BSing me around and just not wanting to do the warranty work. I had alot of things crap out on my previous BMW and im hoping that my tacoma isn't gonna be the same way.
    but, on the bright side; my stereo and my Ultimate lift kit from toytec is coming in this week :) !!!!!:D
    ps. i shouldn't need UCA's on a 3" lift right?
  2. Oct 8, 2012 at 5:04 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    everyone has it, its normal
  3. Oct 8, 2012 at 5:16 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Yup, the tick is (unfortunately) 100% normal on Tacos. If you look around here there are plenty of threads about it. Sorry, I can't answer your UCA question, but I'll give you a bump. Welcome to TW!
  4. Oct 8, 2012 at 5:17 PM
    slodc4
    slodc4 Conceal Carry
    Steven
    Pink Hill, NC
    07 TRD SR5 offroad
    LIFTED
    Completely normal. I was worried about purchasing mine due to the tick...50k miles later still the same tick at the same volume
  5. Oct 8, 2012 at 5:19 PM
    DrewH
    DrewH Well-Known Member
    You should replace your uca's with a 3inch lift.
  6. Oct 8, 2012 at 5:20 PM
    slodc4
    Steven
    Pink Hill, NC
    07 TRD SR5 offroad
    LIFTED
    Also i would get uca's with the 3" lift. I just installed my toytec lift with light racing a arms and got my truck aligned and the alignment guy said my suspension was way off and that without the ucas it wouldn't have came out perfect
  7. Oct 8, 2012 at 5:27 PM
    nammerz
    nammerz [OP] Member
    Marysville, wa
    09 Tacoma DC
    haha thanks for the response guys. man this forum is way better than the BMW forum. At least now i know that tick is normal as long as it doesn't start sounding like gun shots we're good. haha. shoot. I thought I was trippin! lol. Its a tough decision on the UCA topic its pretty much 50/50. I guess worse case scenario i can't align my car and gotta wait 5 days for shipping. haha.
  8. Oct 8, 2012 at 5:48 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Google "Toyota Tick". You'll get a lot of responses about it. I found it out from this site before I noticed it on my truck. It's not going to harm anything on your truck. It's only going to annoying you for a bit and then you'll get use to it. I've heard people say "if you run premium gas it goes away". Running premium doesn't do anything. The "tick" is just one of those quirks these trucks have.
  9. Oct 8, 2012 at 5:59 PM
    RedDragonTaco
    RedDragonTaco Knight Industies Toyota Tacoma
    Slc, UT
    2007 Double Cab TRD Sport
    Toytec 3" Ultimate w/ LR UCA's, 18" Rockstar rims, Nitto Grappler 285/65/18, OEM roof rack, foglight anytime mod, front bull bar and Smitty side steps, tonneau cover, debadged, BHLM, blacked out tail lights, stubby antenna, flowmaster
    I've got the toytec 3" and LR UCA's and love the setup. I hate the ticking noise, I need to get exhaust to help drownd it out
  10. Oct 8, 2012 at 6:10 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I have LR UCA's with my Toytec lift too. May or may not need. I just bought them right off the bat. Could just install as is and see if you can get it aligned within spec without new ones.
  11. Oct 8, 2012 at 6:18 PM
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    I don't notice it running on premium unless it is an exceptionally cold day. OP, when I used to run regular, I found that letting the truck warm up at an idle for a few minutes before driving helped.
  12. Oct 8, 2012 at 7:12 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    That's not the tick, that's the slap, which some of us have too. Unless you're talking the 87 octane ping, which I definitely get if I run it. The true tick is easiest to hear at idle.
    Blasted noisy engine... what a shock coming from my Fit. That L15A1 was so quiet it wasn't audible at all unless the hood was open or the cooling fan kicked on. Too bad they only sold it here for 2 years. It was a marvel of engineered finesse.
  13. Oct 8, 2012 at 7:51 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    The "Search" Function is your friend.
    Try here:
    "Ticking engine".......(one fix)
    By Chris 4x4
    CC
  14. Nov 1, 2012 at 9:40 AM
    Cobalt719
    Cobalt719 Well-Known Member
    Chesapeake, VA
    '12 4 Banger PreRunner DC
    LED Interior Lights, Tailgate Anit-Theft Mod, OEM Skid Plate, Aftermarket Fogs, Tow Hitch
    Okay so not to beat dead horse. But I'm trying to figure out what the noise I hear is and I've found stuff on pings, ticks and knocks. I have a 4 Cyl and when it is cold outside i hear what i would maybe call a tick (but I supposed it could be a ping or knock?) during acceleration and it will do it anytime I accelerate up until the engine warms up. I'm gonna guess that this is normal from the various topics about it but who knows.
  15. Nov 1, 2012 at 10:30 PM
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    Everyone that has a Toyota or Lexus has a ticking noise and usually 2 different ones. One is from the emissions equipment and the other is from the block being thin aluminum. The internal parts aren't muffled. Not a problem, just noisy!
  16. Nov 3, 2012 at 7:25 AM
    Cobalt719
    Chesapeake, VA
    Cool thanks!
  17. Nov 3, 2012 at 9:10 AM
    ssmith29440
    ssmith29440 Well-Known Member
    2012 Tacoma TxPro Trd
    Mine started ticking after the first oil change.
  18. Nov 3, 2012 at 9:11 AM
    Cobalt719
    Chesapeake, VA
    What year? Did they put in the right oil?
  19. Nov 3, 2012 at 12:15 PM
    ssmith29440
    2012 V6. Service guy said it was a non synthetic and they would see me in 5 K miles or 6months. Whichever comes first.
  20. Jan 6, 2013 at 6:39 PM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    I have a tick as well mine is a 2.7 13' only happens at operation temp at idle coming from drivers side.
