Ticking noise at top end of RPM range
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmazur, Sep 9, 2009.
  1. Sep 9, 2009 at 5:24 AM
    jmazur
    jmazur [OP] Member
    Justin
    Pittsburgh, PA
    04 SR5
    Sometimes after a cold start, I've noticed a ticking noise that only occurs at the top end the rpm range just before I need to shift into the next gear. After a little while, the noise disappears. It almost sounds like something could be rattling/vibrating, but I'm not sure. It is an 04 SR5 with 95, 000 miles and the 2.7L engine. Any insight would be appreciated!
  2. Sep 9, 2009 at 9:39 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    the only ticking i ever hear is the lifters, they get worn out and have some play. if it is the lifters, not much you can do, they are hard to get to
  3. Sep 9, 2009 at 11:03 AM
    jmazur
    jmazur [OP] Member
    Justin
    Pittsburgh, PA
    04 SR5
    Thanks rab89
  4. Sep 9, 2009 at 11:07 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    if you are getting ticking at 2000-2500 rpm after cold soak there is a tsb for that to replace the manifolds
  5. Sep 10, 2009 at 11:48 AM
    maddog61
    maddog61 Member
    Revelstoke,BC Canada
    04 4x4 2.7 Tacoma
    I also have 2.7 2004......its piston slap,happens in the cooler winter months.....never noticed with my 1997, they must have changed the head design?? The dealer though it was the timing chain,but changing the chain made no difference. After driving for a couple minutes and engine warms up, it disappears. Sure sounds the shits.....have 80000 miles no engine problems...knock on wood
  6. Sep 13, 2009 at 9:37 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    no problem man
  7. Sep 14, 2009 at 11:00 AM
    jmazur
    jmazur [OP] Member
    Justin
    Pittsburgh, PA
    04 SR5
    Thanks for the info guys.
