ticking noise help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fitryders2, Jan 11, 2011.
  1. Jan 11, 2011 at 12:43 PM
    fitryders2
    fitryders2 [OP] Well-Known Member
    shawn
    virginia
    07 trd sport
    ive got a 07 tacoma. only thing done is the lift tires and a k&n. i did the spark plugs the other day and i know i gapped them correctly and tightened them. the spark plugs are densos from toyota. and i checked just to make sure the part number was correct.
    problem:
    i get home from work today and its making a faint tapping sound.sounds mainly on the driverside. if i rev it to about 1300 rpms just at a sit still i can hear it pretty distinctly. anyone have any ideas? almost like a valve tap. but i dont see that with 42,xxx miles. i appreciate the help in advanced.
  2. Jan 11, 2011 at 3:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    All these engines tick. Its normal.
  3. Jan 11, 2011 at 3:28 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    where you hearing the ticking... Is your air on in the cab?? Does it sound like a skipping CD?
  4. Jan 11, 2011 at 3:30 PM
    Jpwarrior
    Jpwarrior Active Member
    Justin
    Alameda
    06 DC TRD 4x4 Silver
    Undercover classic
    Yea, your just paying attention to the engine now that you did all that work. I was doing the same thing. It's OK! These trucks all do it. There are 5 guys at work that have the same truck in different years. I had each one of them start up their engines. The guy with the 2010 was a little more quiet but other than that they all sounded the same.
  5. Jan 11, 2011 at 3:32 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    I find my ticking is more prominent on the drivers' side as well.
  6. Jan 11, 2011 at 4:09 PM
    fitryders2
    shawn
    virginia
    07 trd sport
    its not your average tick to me. but you could be right i might just be paying to much attention. but if i start to rev slowly it goes away then comes back stronger. almost like no oil. but i know i have oil. i could be freaking out your right. but im looking at it more tomorrow. and possibly dealership. just to ease my mind some.
