Ticking noise on 99 2rzfe
Discussion in 'Technical Chat' started by littletruck00, Feb 10, 2025.
  1. Feb 10, 2025 at 10:52 PM
    littletruck00
    littletruck00 [OP] New Member
    Jon
    1999 Tacoma 2.4 extended cab
    1999 Tacoma 2.4 with 306k miles. There’s this dam ticking noise at idle and is follows the rpm’s I can’t pinpoint but by hearing closely I can tell it’s coming from the top drivers side of the engine. I want opinions on what this might be or if anyone has experienced this before it would be a great help. Truck runs great, accelerates normal and no rough idle
    https://youtube.com/shorts/Y_wXhXvXwuU?si=WTfJvVJ1fBexBBpK
  2. Feb 11, 2025 at 11:27 AM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    Try some Marvel Mystery Oil, Maybe 8 ounces before an Oil and filter change and drive for a 100 miles at 30 minute or more rides! then change with Full Synthetic Motor Oil and a good filter !
  3. Feb 12, 2025 at 9:19 AM
    littletruck00
    Jon
    just did an oil and oil filter change with some full synthetic a couple days ago. she’s quiet on a cold start but once up to operating temp the ticking is noticeable. Some ppl have said this is normal for high mileage Tacoma 4cyl what do you think? Thanks
  4. Feb 12, 2025 at 9:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Spark plugs are tight? PCV, maybe. Exhaust gasket leak.
    littletruck00[OP] likes this.
  5. Feb 12, 2025 at 9:00 PM
    littletruck00
    Jon
    I havnt checked the spark plugs yet I’ll do that when I get the chance and make sure they are all torqued down to spec. Pcv or exhaust gasket, maybe a possibility. I’ll look into it more this weekend and keep you guys posted
