Ticking Noise - Timing Belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pidro_el_pirata, Dec 27, 2012.
  1. Dec 27, 2012 at 9:52 PM
    pidro_el_pirata
    pidro_el_pirata [OP] Well-Known Member
    I'm hearing some noise that sounds like ticking, it is independent of vehicle speed but directly affected by engine speed, so I think it is coming from a belt. It is loud enough to hear from the drivers seat while idling at a light and it is near the front of the engine bay too. I don't have an expert ear for this kind of stuff and it is hard to locate but I saw a thread for a different model year that mentioned timing belts should be replaced about 90k, does this apply to my 2000 Tacoma? Could this be making that noise?
    I have not replaced any belts at all during the time I have owned the truck. I bought it about four years ago at 70k, it is now at 135k.
    If I take it to a mechanic what would they check, and are those things I can check myself?
  2. Dec 27, 2012 at 10:36 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Timing belt will not cause a tick....
    The timing belt can snap at anytime without warning
    With 135k miles - you're on BORROWED TIME. Get the timing belt, water pump, and thermostat changed.
  3. Dec 28, 2012 at 6:51 PM
    pidro_el_pirata
    Yikes. Any other opinions on this?
    Which of those can I do myself?
  4. Dec 28, 2012 at 6:52 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    All of them if you know how. Or know someone who will be willing to help.
  5. Dec 28, 2012 at 7:01 PM
    pidro_el_pirata
    Okay, I'd classify myself as a shade-tree mechanic that has no problem with oil filters but I've never gotten deeper than the spark plugs on my truck. I saw another thread saying it would take a dealer 4 hours to do these things, that probably equates to an entire weekend for me and a lot of mistakes and redoing things... Hmmmm
  6. Dec 28, 2012 at 7:46 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Looks like a 4-cyl. Don't know about that yr., but on the older 4 cyl's there is a timing chain, with a chain tensioner and 2 chain guides. If one of the guides breaks it will cause that type of noise.
    I had that happen on two motors, with about the same milage.
    If it has a belt, it may be as simple as a valve being out of adjustment.
  7. Dec 28, 2012 at 7:49 PM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    You sir have a timing chain. They rarely break
  8. Dec 29, 2012 at 10:18 AM
    pidro_el_pirata
    The chain or the guides?
  9. Dec 29, 2012 at 10:23 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    the guides wear and break.
  10. Dec 29, 2012 at 12:17 PM
    superswamper003
    Hendrik
    The guides are only plastic so they wear out as the above said
  11. Jan 15, 2013 at 4:49 PM
    pidro_el_pirata
    Just spoke with a mechanic who was recommended by a friend. He will be investigating the noise starting with new belts.
    How much should I expect it to cost for him to change the water pump and thermostat too?
  12. Jan 15, 2013 at 8:21 PM
    superswamper003
    Hendrik
    Well you have a timing chain not a timing belt but anyways, the water pump and thermostat shouldnt be too much more at all because those two parts are very easy to access once you have everything else removed for the timing chain job. The kit for your truck is around 220 bucks not including the thermostat, but the thermostat isnt much at all.
  13. Jan 15, 2013 at 8:57 PM
    pidro_el_pirata
    At this rate we are talking about the other belts and not the timing chain any more. I want to start with the easy stuff. Also I read up on the water pump & thermostat replacement discussion. Lots of different opinions. Ultimately I'm not going to do anything right now unless absolutely necessary.
  14. Jan 15, 2013 at 11:00 PM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    My 2.7 has a tick. It only ticks when I let off the gas or the engine is idling. It only seems to do it when it's cold out. Never caused an issue.
  15. Jan 15, 2013 at 11:03 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Have him check your valves may just need to be adjusted. Mine had a tick, was out of spec, small adj and good to go
  16. Jan 16, 2013 at 4:06 PM
    Tacoma7382
    Tacoma7382 Member
    Supercharger
    I would check under the hood to see if there is a sticker with a date or near the timing belt housing and last but not least, near the radiator shroud.. I have an 03 4x4 DC with about 115k and I'm getting the timing belt water pump thermostat all done next month.. Good luck!
  17. Jan 16, 2013 at 4:30 PM
    pidro_el_pirata
    As others have said, and I have since verified, I have a timing chain. I have read both sides of the debate about replacing the water pump and at this time I will not be replacing it unless the mechanic recommends otherwise. I am willing to take a risk and wait until it shows some signs of wear before replacing it. I pay AAA and they will tow me 200 miles if something fails.
  18. Jan 18, 2013 at 9:26 AM
    pidro_el_pirata
    The mechanic found nothing wrong and said the engine is just getting a little "noisy" in its old age. Belts looked fine too.
  19. Jan 18, 2013 at 9:30 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Try a thicker oil
  20. Jan 18, 2013 at 9:32 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    ^^^ Good news!
    Edit: second post above about no issue.
