Ticking Noise - Timing Belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pidro_el_pirata, Dec 27, 2012.
  1. Jan 18, 2013 at 9:35 AM
    BamaToy1997
    Bill
    Navarre, FL
    It is not unusual for these 4 cylinders to develop a small tick. The valves do not have a normal adjustment, thus when things wear overtime, you can get a tick. Sometimes the chains can make a tick noise (the 4 cyl has a timing chain and a balance chain) If the noise is of a huge concern, and it IS valve tick, then the way to fix this is to replace the shims with the correct size. This takes some time, and can get a little costly, as the shims are around $12 each, and there are 16 shims total. Of course not all shims will need to be replaced. Just giving you some additional info.
  2. Jan 18, 2013 at 6:09 PM
    pidro_el_pirata
    pidro_el_pirata [OP] Well-Known Member
    Thanks for all the help guys. I guess it's a good thing that I don't have to spend money on it, but I was hoping that it was an easy fix like the belts were old and then I could rest easy when they were replaced. Now I'm just wondering what will fail first :/ lol
  3. Mar 11, 2013 at 8:41 AM
    maza mike
    maza mike Member
    1996 Tacoma 2.7 3rz automatic extended cab
    This tick problem sounds similar to mine, my mechanic is backed up for months, did listen to my vehicle, said the tick may possibly be coming from the timing chain cover area.
    My question, would a bad timing chain or guide cause the vehicle to lose power/chug/sputter. My tacoma (2.7 3RZFE automatic) does this and I am trying to narrow the problem.
    Help!!!!
  4. Mar 11, 2013 at 8:56 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Ive gotta tick on my 2.7, only does it cold-when on the gas in D. When I pop it in N its GONE.
    Good luck guys lol
