Ticking /rattling sounds
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheTacoMarine, Jan 13, 2023.
  1. Jan 13, 2023 at 8:26 AM
    TheTacoMarine
    TheTacoMarine [OP] Well-Known Member
    2016 Tacoma TRD Sport
    All right, so I just got back from the dealership and they cannot diagnose his problem. There is a ticking sound coming from the driver side dash or a steering wheel that I cannot identify. I have attempted to look by the foot pedals but it’s intermittent and is not constant and he won’t have any idea. Only happens when driving not idle
    https://youtube.com/shorts/Y8GMoWeRPE0?feature=share
  2. Jan 13, 2023 at 8:36 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Taco X and TheTacoMarine[OP] like this.
  3. Jan 13, 2023 at 8:36 AM
    TheTacoMarine
    You have a valid but but yes I did that and it’s still there. Also can confirm it’s not the door pillar because I’ve already wedged some foam in there the first year I had it.
  4. Jan 13, 2023 at 8:37 AM
    TheTacoMarine
    Can confirm no bomb or alarm. Tool used was a buddies K9
  5. Jan 13, 2023 at 8:44 AM
    bockafer
    bockafer Well-Known Member
    Earth
    22 Limited 4x4 MGM
    Sunglasses in the sunglass holder?
  6. Jan 13, 2023 at 8:53 AM
    TheTacoMarine
    Nope it’s coming from the cluster gauge or by the pedals for sure
  7. Jan 13, 2023 at 8:54 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    What year of truck and how many miles?
  8. Jan 13, 2023 at 8:55 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    Access cab or crew cab, and do you notice the noise more when the outside temperature is colder?
  9. Jan 13, 2023 at 8:57 AM
    TheTacoMarine
    2016 TRD SPORT with 94k
    CaptainBart45[QUOTED] likes this.
  10. Jan 13, 2023 at 8:58 AM
    TheTacoMarine
    Well started about a two weeks ago and the temps where 20°F now it’s 60°F and doesn’t seem like weather has a play.
    It’s a crew cab
    CaptainBart45 likes this.
  11. Jan 13, 2023 at 9:09 AM
    CaptainBart45
    Bart
    Work in progress...
    Have you check under the hood and make sure every thing is stowed away?
  12. Jan 13, 2023 at 9:36 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    We don’t have the directional advantage you do listening to video sounds. Are you sure it’s not something from the engine compartment, maybe something as simple as an unsecured hood prop rod?
    Here’s a tool that may help isolate the area the sound is coming from, though I would have a passenger use it as you drive.
    https://www.amazon.com/Lisle-52750-...hoscope+automotive&qid=1673630704&sr=8-8&th=1
  13. Jan 13, 2023 at 9:37 AM
    TheTacoMarine
    I’ll check that out but im almost sure it’s coming from the pedal area or up in there
  14. Jan 13, 2023 at 9:38 AM
    22Coma6MT
    Sorry, can't help. I had a ticking issue with my access cab that was worse when it was cold. Turned out to be the access cab door panels hitting a metal support bracket. I covered the brackets with gorilla tape, bent them slightly to put more pressure on the panel, and installed some sound deadening material.
    araknon2022 likes this.
  15. Jan 13, 2023 at 11:08 AM
    mitt22
    mitt22 Well-Known Member
    In the video there might be some hints. It didn't occur while accelerating, but when you got to constant speed, it seems to start. It almost seemed in sync with the bumps in the road. The tick loudness also seemed in tune with the camera bounce.
    Really sounds like there is something loose that takes very little effort to swing, roll, or bounce into another part. Accelerating pins it against or moves it away from the contact for a momentary time.
    Could have something fallen down the defrost vents? No idea what else it could be.
    Could you use a stethoscope to trace where it is loudest?
    TheTacoMarine[OP] likes this.
  16. Jan 13, 2023 at 11:11 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    my windows make weird clicking noises from the cab flexing. it's worse when cold. I sprayed some silicone around all the trim and it helped a little bit. check the steering shaft/linkage in the engine bay and see if there is any play in it.
  17. Jan 13, 2023 at 12:35 PM
    TheTacoMarine
    Tore the bottom of the dash off couldn’t find what it was will have to keep looking tomorrow
  18. Feb 22, 2023 at 1:23 PM
    TheTacoMarine
    Well, it's been over a month and I wanted to update everyone.
    So I was approaching my truck yesterday and it was a fairly windy day. I started to hear these knocking sounds! I was like sh!t now what could be going on with my truck making yet another sound. I end up standing near it for a few minutes periodically hearing the knocking sound. I follow it the best I could with my ear. Low and behold the engine guard flap above the driver-side tire had come out. The damn plastic piece used to hold it in was tapping on the frame! I can't believe that was it. No more constant knocking in my truck!
    theshandon and broderwd like this.
