Ticking Sound From Engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95Yota4x4, Dec 20, 2011.
  1. Dec 20, 2011 at 6:09 PM
    95Yota4x4
    95Yota4x4 [OP] -FURY FROM THE SKY
    J.D.
    Houston, Tx
    Black 95 Tacoma, reg cab, 2.7L 4 cyl, 4x4
    4" lift
    I incorporated some sea foam with my last oil change. since then i have noticed a ticking noise coming from engine. thinking it may be the gunk that was muffling the noise got washed off by the sea foam. do i need to check the valves? also oil pan has started a very slow drip since the sea foam. thinking that's due to the gunk that was holding that gasket together has been cleaned out by the sea foam too. gonna change gasket with next oil change. no biggie, more concerned with strange sound. anyone come accross ticking sound before? if so what to do?:confused:
  2. Dec 20, 2011 at 6:13 PM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    when does it tick? at idle, in neutral and higher rpms, under load, acceleration???... valve tick? manifold leak?
  3. Dec 20, 2011 at 7:47 PM
    95Yota4x4
    J.D.
    Houston, Tx
    4" lift
    Ticks all the time when running. Possible it's the manifold.
  4. Feb 24, 2012 at 4:48 AM
    GrEeN WeEnY
    GrEeN WeEnY Well-Known Member
    Aaron
    Behind Enemy Lines, OR
    2023 TRD Sport DCLB, my sixth Tacoma
    Thats the injectors, it's normal
