Ticking sound on passenger dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blade29, Apr 8, 2024.
  1. Apr 8, 2024 at 8:23 PM
    Blade29
    Blade29 [OP] Member
    Blake
    2011 Tacoma TRD Off Road
    Hey guys,
    On the passenger side of my 2nd gen Tacoma, there is an occasional ticking sound that sounds like it’s coming from under the dash where the airbag is located. Bumps in the road seem to make it worse. Wondering if anyone has a diagnosis for the problem. Thanks!
  2. Apr 8, 2024 at 8:32 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Jimmyh likes this.
  3. Apr 8, 2024 at 8:37 PM
    Blade29
    Blade29 [OP] Member
    Blake
    Definitely intermittent. I’ll drive one day without hearing anything, and the next it will create noise every time I drive.
  4. Apr 8, 2024 at 8:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Next time it does it mess with your A/C controls and see if it changes/quits, if it does then take a look behind the glovebox and see which one is ticking. If it doesn't then we will have to check elsewhere.
    Jimmyh likes this.
  5. Apr 8, 2024 at 8:43 PM
    Blade29
    Blade29 [OP] Member
    Blake
    Okay thanks!
  6. Apr 10, 2024 at 5:23 PM
    Blade29
    Blade29 [OP] Member
    Blake
    Couple things I figured out the past two days:
    -Doesn’t seem to tick when I start it up in the morning but gets progressively worse throughout the day
    -Messing with the AC controls doesn’t seem to affect it at all
    Wondering if it has anything to do with temp outside? Let me know if you have any suggestions for me. Thanks.
  7. Apr 10, 2024 at 8:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    When it is ticking place your head over by the passenger side under the dash and locate the place the ticking is coming from.
  8. Apr 10, 2024 at 8:44 PM
    soggyBottom
    soggyBottom Well-Known Member
    Pull your air filter out and check for leafs in or around the fan
  9. Apr 10, 2024 at 11:08 PM
    Blade29
    Blade29 [OP] Member
    Blake
    Sounds good
    Jimmyh[QUOTED] likes this.
