Ticking Sound Under the Hood
Discussion in '3rd Gen. Tacomas (2016-2023)' started by El Tut, Jan 20, 2024.
  1. Jan 20, 2024 at 3:35 AM
    El Tut
    El Tut [OP] Member
    Jeff
    Maine
    2019 Tacoma Sport
    Borla Cat-back, AEM CAI, 2" - 1" lift, Ultra wheels
    The sound is not very pronounced after being started and at idle. It increases in volume when accelerating and then quiets down when rpm's drop in the upper gears. It sounds like it is coming from the driver's side top of the engine towards the back. It seems to have started right after the truck slowed down, seem to shake and rattle a bit from underneath, and then stalled out (which it never does) at a stop light. Several warnings came up on the dash "high transmission fluid temp", "low oil pressure", and a couple others that went away too quick to read. I let the truck sit for just a minute and I was able to restart it. The check engine light is not on and it threw no codes. I replaced the crankshaft position sensor, which it looks like that was a waste, because that what was recommended after doing a bit of research. Ideas?
  2. Jan 20, 2024 at 3:52 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Fuel pump ?
  3. Jan 20, 2024 at 7:09 AM
    BirdBrain
    BirdBrain Well-Known Member
    2021 4wd Off-Road
    Sounds like it needs to go in for service.
