ticking sound when starting my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kauairandall, Nov 6, 2010.
  1. Nov 6, 2010 at 10:54 AM
    kauairandall
    kauairandall [OP] Senior member
    randall
    hawaii
    2006 TRD toyota tacoma v6 4x4
    6" fabtech suspension lift 3" body lift 3"gap guards K&n intake MBRP exhaust billet grille stubby antenna maglight mod Debadged No mudflaps 30% tint Interior: Alpine CDA-105 deck Alpine MDA- sectrum analyzer Alpine amp 12" kicker sub Wet okole seat covers
    I have 2006 toyota tacoma, Trd 4x4. lately I've been having problems starting my truck. when starting the truck the starter sounds weak as if the battery is dead or the truck has bad terminal problems. The starter makes a tickin sound and either takes a while to start or just didn't start at all. so I jumped the truck with battery cables and it started up fine. When starting after i jumped the truck it has no problems.. I tested the batter and it read 12v. so earlier i started the truck it made the low crank sound as if the battery was dying but still started up.. I can't figure out why it's starting the way it does. i just recently installed a 6" fabtech suspension lift. Would the lift be a cause of the bad start on my truck.?:(
  2. Nov 6, 2010 at 11:04 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Its definitely either a battery problem or a wire problem. Try either buying a new battery or charging the one you have. Make sure both terminals are clean. : )
  3. Nov 6, 2010 at 11:05 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    just go to autozone they will test your battery for free
  4. Nov 6, 2010 at 11:07 AM
    jivewalker
    jivewalker me gusta pechos firmes
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS
    sounds like you need a new battery or a good re-charge. Take the battery and have it load tested. Just because it reads 12v doesn't mean it can handle the load of a start. If you want, put a meter across it and watch the volts DC and have someone else crank the engine. i can almost guarantee that under the load the voltage will drop bad.
  5. Nov 6, 2010 at 11:12 AM
    kauairandall
    randall
    hawaii
    ok. I havent tried that yet.. but after having the low crank, and the truck starting up.. it starts up perfectly fine.. until i let it sit for a while and it does the same thing. ill have the load checked.
  6. Nov 6, 2010 at 11:16 AM
    jivewalker
    Jack MeHoff
    Chucktown
    Really sounds like the battery. Question will be what caused it to drain in the first place? So, battery might still be good and just need a re-charge. Short trips won't recharge it, needs to be charged on a charger or very long trip. Was there any wiring work done recently? Check all connections as well. Loose ground at the battery terminal may be a culprit. Good luck and post waht you find. BTW, welcome to TW!:)
  7. Nov 6, 2010 at 11:17 AM
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    Don't overlook the obvious-->loose battery terminals. I had same prob with my Camry. Couldn't figure it out until I decided to check battery cable connections. Sure enough, negative cable was loose. Tightened her up and problems were gone. Just my .02
  8. Nov 6, 2010 at 11:19 AM
    jivewalker
    Jack MeHoff
    Chucktown
    LOL, thinking the same thing at the same time :laughing:
  9. Nov 6, 2010 at 11:20 AM
    kauairandall
    randall
    hawaii
    thanks for the welcome, but yes. i installed an amp and sub, so there is a power wire to the battery. but maybe a good charge will do.. if not a new battery .. thanks for the help..
  10. Nov 6, 2010 at 11:24 AM
    jivewalker
    Jack MeHoff
    Chucktown
    Make sure your amp is turning off with the ignition/head unit
  11. Nov 6, 2010 at 8:16 PM
    kauairandall
    randall
    hawaii
    so i had the battery checked , terminals cleaned and tightened. battery is good even when the load is put on. found out that the ticking sound is not from a dead battery, it's from bad conacts on the starter which you can only get genuine parts straight from toyota. costs like 40$$. but thanks for the help..
