Ticking sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neticstacoma, Dec 30, 2024.
  1. Dec 30, 2024 at 12:15 AM
    Neticstacoma
    Neticstacoma [OP] Well-Known Member
    I have 2008 tacoma 2.7l suddenly I start hearing a ticking sound from below but I sound will not come when the car is in Neutral I raised the RPM to check and no sound is there it’s only coming when the car is moving and on lower rpm only
    I recorded that ticking
    https://jmp.sh/s/APpAeddJNTNZ9oFur2tg
    Please share your knowledge with me
  2. Dec 30, 2024 at 11:04 PM
    Neticstacoma
    Guys anyone
  3. Dec 31, 2024 at 12:26 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Doesn't sound like ticking, sounds more like something large & flat vibrating. Crawl under and check catalytic converter heat shields and and splash guards for loose bolts.
    robssol likes this.
  4. Jan 1, 2025 at 11:19 PM
    Neticstacoma
    thank u for your reply I checked and found the heat shield above the catalytic converter was loose and I tied it up but the sound is still there so it’s not coming from the shield
  5. Jan 3, 2025 at 12:23 AM
    Neticstacoma
    Anyone faced this issue?
  6. Jan 3, 2025 at 4:31 AM
    Why I oughta...
    Why I oughta... Well-Known Member
    2014 Base AC 4x4 2.7 5speed
    If it's only "ticking" when moving, maybe have cv joints and u joints checked.
  7. Jan 3, 2025 at 5:32 AM
    Neticstacoma
    I doubt it coming from there I don’t know but am suspecting that its coming from the transmission or the drive shaft because the sound is coming from that direction
  8. Jan 4, 2025 at 2:11 AM
    Neticstacoma
    Checked and nothing to be loose or causing that sound
