Ticking time bomb?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dreamsoreal, Jul 22, 2022.
  1. Jul 22, 2022 at 4:43 PM
    Dreamsoreal
    Dreamsoreal [OP] Member
    Jesse
    1999 4wd 2.7L
    Hello all,
    First time poster here needing some help! I have a automatic 4WD 2.7 L MFI DOHC 4 cyl with 200,xxx miles. I'm having an issue with a very light ticking noise coming from the driver side of the engine bay. At idle zero ticking, but when traveling from a dead stop to 20-30 MPH I notice a slight ticking while accelerating. The ticking stops immediately once acceleration is decreased. Engine power and acceleration seems normal, but I would like to diagnose if possible. If anyone has any recommendations or experience with this I would greatly appreciate it. Will upload a video to provide some insight.
    Note : recently had a P0402 code for excessive EGR flow detected. This issue has been fixed ( was the EGR VSV that needed to be replaced)
  2. Jul 22, 2022 at 4:45 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  3. Jul 22, 2022 at 4:47 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    Hi Jesse. Please listen under the hood. If it’s related to engine speed you should hear it without having to drive it, and hopefully locate it.
    With the hood open and in neutral (of course!) blip the throttle at the throttle body and listen.
  4. Jul 22, 2022 at 4:52 PM
    Dreamsoreal
    Jesse
    1999 4wd 2.7L
  5. Jul 22, 2022 at 4:55 PM
    Dreamsoreal
    Jesse
    1999 4wd 2.7L
    I appreciate the timely response's as I said it's very slight so it still may be difficult to hear. This ticking is not noticeable when the idle or increasing rpms from a stationary position. The ticking only happens when in motion
  6. Jul 22, 2022 at 4:58 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Check your spark plugs and exhaust manifold.
    vern650, Taco critter and Wulf like this.
  7. Jul 22, 2022 at 5:00 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Taco critter likes this.
  8. Jul 22, 2022 at 5:01 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Hard to tell with the wind noise but I would say exhaust leak at the manifold, could be a cracked manifold or blown gasket. Get someone to powerbrake it while listening under the hood and see if you can locate it.
  9. Jul 22, 2022 at 5:06 PM
    Dreamsoreal
    Jesse
    1999 4wd 2.7L
    Thanks everyone much appreciated
  10. Jul 22, 2022 at 9:09 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    Sounds like an exhaust leak to me.
    Dreamsoreal[OP] likes this.
  11. Jul 27, 2022 at 11:16 AM
    2009Access4x4
    2009Access4x4 Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Exhaust manifold leak. I have the same problem unfortunately. Just got underneath the chassis with the tech and we found it. I’ve noticed a quick hiss when I punch the throttle for a few years now. These rust out all the time.
  12. Jul 27, 2022 at 11:23 AM
    2009Access4x4
    Shane
    The ticking is just normal exhaust lifter tick but you can hear it louder because you likely have an exhaust manifold leak.
  13. Jul 31, 2022 at 11:11 PM
    Dreamsoreal
    Jesse
    1999 4wd 2.7L
    Thanks everyone, will have some time to work on it this weekend. Appreciate all the feedback
