Ticking/Winding Noise from Rear End
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Andy040715, Jan 1, 2013.
  1. Jan 1, 2013 at 3:19 PM
    Andy040715
    Andy040715 [OP] New Member
    Andrew
    MAINE
    2006 Tacoma V6 TRD
    K&N Intake
    Hey all, my 06 tacoma v6 trd auto 121k is making a strange noise lately. When I am driving 25-50 mph and I just feather the gas, a winding/whirling sound is coming from the rear end of my truck. It just started doing this when ive been going from 2x4 to 4x4 with the weather we are getting here in Maine. When I bought it 1000 miles ago, the toyota dealership said they replaced the barrings in the rear end. I am a total noob and have limited skills in repairs/recognizing issues. Any help would be appreciated. Thanks
  2. Jan 1, 2013 at 6:16 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Sounds like it could possibly be a pinion bearing from your description. A pinion bearing failure can make noise under load but quiet down or disappear when letting off the accelerator.
  3. Jan 1, 2013 at 7:18 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Anytime fog light mod Bed mat LED Map and Dome LED bed lights Red LED floor lighting in cab Westin Bull Bar Westin Side Steps Treklights 18" LED Spot bar 2 Blitzpro 6D 2 Blitzpro 6LZ as rear aux lighting Flyzeye V2 Anytime rear camera mod Extang Trifecta tonneau Extra d-rings in the bed Pop n Lock Tailgate Handle
    i had what you're describing when i bought my truck last april. I replaced rear diff fluid with mobil 1 synthetic and greased the drive shaft and the noise went away and has not come back
  4. Jan 1, 2013 at 11:43 PM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    Check fluid first. Maybe they re-installed the gaskets improperly and it has slowly drained to an unsuitable level.
    If yes, break the seal, inspect, (maybe take and post some pictures here for the more experienced members), re-seal, and fill it up.
    If its still full, I would still drain the fluid, Look for anything unusual in it, and replace it with a fresh synthetic. Who knows, maybe its the wrong fluid. I remember my previous 4x4's were very particular about what diff fluid was in them - sometimes requiring additives for a totally smooth performance.
    It is possible that its a pinion bearing, but better to eliminate some variables first. They above should take an hour and no more than $15.
  5. Jan 2, 2013 at 12:39 AM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    If there's still a used vehicle warranty in force, take it back to the dealership and have them look at it. FWIW, any time there's a problem coming from the same area as a recent repair, I look there first. Whatever work the dealership did prior to purchase should be inspected.
