Tie down hooks on a 2010 PreRunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTP, Dec 4, 2009.
  1. Dec 4, 2009 at 8:38 PM
    MTP
    MTP [OP] Member
    Mundelein, IL
    2019 Off-Road MT
    I just bought my 2010 Tacoma PreRunner. It has two rotating hooks on the floor of the bid located near the tailgate. There are two holes in identical places near the other end of the bid.
    Should there have been hooks in the front? Did someone forget to install them? Or, Is it just another add-on?
    Thanks,
  2. Dec 4, 2009 at 8:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Dec 4, 2009 at 8:44 PM
    MTP
    MTP [OP] Member
    Mundelein, IL
    2019 Off-Road MT
    Ahh... I guess that makes sense. But It makes it almost impossible to tie a motorcycle down.
    Are the rails and removable clamps strong enought to support a motorcycle?
    Will you damage your bed by installing hooks in the front because of poor draining?
    Thanks.
  4. Dec 4, 2009 at 8:48 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    I would definitely do the extra d-ring mod. I put a 4wheeler in mine and used the rails/cleats to secure it near the cab. The rails started to bend up and you could hear things cracking. I wouldn't trust that method if you plan on doing a lot of motorcycle hauling. It's just cheap plastic. Neat concept for the rails, but could be stronger.
  5. Dec 4, 2009 at 9:00 PM
    MTP
    MTP [OP] Member
    Mundelein, IL
    2019 Off-Road MT
  6. Dec 4, 2009 at 9:34 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Take out the bolt near the back window on the floor. Leave the drain holes alone.
    You'll need to do a little work.
    Install the new d-ring and you're set.
  7. Dec 4, 2009 at 9:46 PM
    AvsFanTRD
    Brandon
    Wyoming
