Tie rod Bolt spins when tighening
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kire, Oct 22, 2016.
  1. Oct 22, 2016 at 12:41 PM
    kire
    kire [OP] Well-Known Member
    Seattle, Wa
    2008 Indigo Blue Tacoma AC TRD
    How can i get my tie rod castle bolt tight when i try to tighten it down the bolt spins??
    I am getting kinda desperate. Please and thanks all.
  2. Oct 22, 2016 at 12:49 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Get the castle nut threaded on just a little bit and then use a large par to pry the tie rod end down so there's lots of pressure on it and start tightening. Once the taper of the bolt sets into arm it'll hold itself.
    FishingInSand and dk_crew like this.
  3. Oct 22, 2016 at 1:07 PM
    kire
    Seattle, Wa
    I will try that, it seems you have to put a ton of pressure down. There is not really anything to lever off of. This is frustrating.
  4. Oct 22, 2016 at 1:57 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Next time you pull the castle nut off wire brush the threads on the tie rod end. That will make reassembly a lot easier.
    FishingInSand likes this.
  5. Oct 22, 2016 at 6:09 PM
    kire
    Seattle, Wa
    Thanks for the advice guys. Thanks for making Tacomaworld is such a great resource.
    dk_crew likes this.
