Tie rod boot off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glockner, Dec 7, 2019.
  1. Dec 7, 2019 at 2:44 PM
    glockner
    glockner [OP] Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    This isn’t normal is it? Also could this be a cause of a clunk sound I hear when going over bumps? Currently under truck trying to pin point clunk sound.
    Beretta4x4 likes this.
  2. Dec 7, 2019 at 2:45 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Not normal and could be a symptom, but not the cause.
    BassAckwards likes this.
  3. Dec 7, 2019 at 2:49 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The problem is the ziptie that has failed to hold the boot over the end of the steering rack. Id get one of the metal clamps from toyota and install that. Steel hose clamp would probably work well too and would be a lot cheaper. Youll want to address the asap as you dont want dirt and grime getting into the steering rack and ruining the seals
  4. Dec 7, 2019 at 2:55 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes that could be your "clunk" But only because someone has been there before. No cable ties from Toyota and the end of the steering tube looks to be beat up.
    Thuguon2.7, SR-71A and Beretta4x4 like this.
  5. Dec 7, 2019 at 2:59 PM
    TheSt|G
    TheSt|G Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    Realistically, it's time to rebuild the rack now. Once a steering rack boot or CV joint boot comes off during road use, it has enough grit in it to cause failure.
    jungleman, Too Stroked and Beretta4x4 like this.
  6. Dec 7, 2019 at 3:09 PM
    glockner
    Scottsdale, AZ
    I am bringing to my local 4x4 shop Monday. What should I tell them?
  7. Dec 7, 2019 at 3:13 PM
    Beretta4x4
    Josh
    Temple, TX
    Exactly what happened and what's going on
    whatstcp likes this.
  8. Dec 7, 2019 at 3:22 PM
    glockner
    Scottsdale, AZ
    Both driver and passenger tie rods look like they are leaking fluid as well, I see an oil like substance on both lower control arms. Could this be a power steering leak?
  9. Dec 7, 2019 at 3:52 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    If the boot has been off for a while you likely sucked dirt into the rack and the seals are shot. Get it fixed pronto to avoid more damage.
    ** Clunk ** Sound is typically an upper or lower ball joint.
  10. Dec 8, 2019 at 5:41 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ok the rack itself does not appear to be leaking but what you don't see is the joint between the rack and the tie rod it is inside the boot. There is a ball joint in there that allows the tie rod to move up and down with the suspension. If there is ware in that joint it will knock like crazy as you drive over uneven surfaces and probable you'll will feel it in the steering wheel. Toyota does not use cable ties to hold the rack boot on so someone has been in there.
    jungleman and Freeheelbillie like this.
  11. Dec 9, 2019 at 8:45 AM
    glockner
    Scottsdale, AZ
    So 4x4 shop called and told me I do have a slight leak in steering rack. They suggest I keep an eye on it for now since Toyota's are known to seal themselves? Passenger wheel bearing was bad which was causing some clunks, so I am having them replace that. Also having truck aligned to try to get rid of some steering wheel vibrations..
  12. Dec 9, 2019 at 10:04 AM
    glockner
    Scottsdale, AZ
    Follow up comment/concern. Where my condo is located, to get to the main highway I have to make a tight u-turn, do this a couple times a day daily on average. Could this have sped the process of wearing out my seals on the rack? I try my best not to take it full lock, but sometimes I can't help it because it is such a tight u-turn.
  13. Dec 9, 2019 at 10:16 AM
    glockner
    Scottsdale, AZ
    I am way too anal about my truck, every noise / clunk I hear or feel concerns me and I overthink everything. Need to learn to just realize its an old truck and will make some noises lol. I will probably end up replacing it, but if I can save myself an extra $700+ for a few months, I'm good with that. I've seen some people mention using Lucas Oil power steering leak fix, but not sure how I feel about that. And yeah, not sure about the wheel bearing thing. I've had a clunk coming from my front passenger side for some time now, I thought it was something to do with the suspension but they said my wheel bearing was bad on that side. Guess I can confirm when I bring it home later today and go over the speed bump at my complex that makes it clunk every time.
  14. Dec 9, 2019 at 10:20 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I wish leaks fixed themselves lol. Maybe there is some kind of additive for the power steering fluid that'll swell up the seals and buy you more time, kind of like with high mileage engine oil...but I dunno. That stuff is usually preventative anyway, once a seal is leaking I don't see how it could possibly fix itself.
  15. Dec 9, 2019 at 10:36 AM
    mauigrown
    mauigrown Well-Known Member
    2011 4x4 DCSB TRD sport
    your clunk sound could be coming from worn out front body mounts. I have that problem.
  16. Dec 9, 2019 at 10:43 AM
    glockner
    Scottsdale, AZ
    That's a good suggestion as well. My truck is getting aligned today too, I was thinking maybe the LCA bolts were loose, they should be torqued to spec after alignment if I'm not mistaken? Guess I'll have to report back this evening when I get my truck back to see if the clunking / steering wheel vibration is gone.
  17. Dec 9, 2019 at 10:50 AM
    Beretta4x4
    Josh
    Temple, TX
    Yep. I have to re-torque mine every off-road trip to 130 ft. lbs.
  18. Dec 9, 2019 at 10:53 AM
    glockner
    Scottsdale, AZ
    Do you notice a clunk sound before you re-torque? My last alignment was in January (6k miles ago), so I guess they have had a lot of time to loosen up even with the moderate wheeling I do.
  19. Dec 9, 2019 at 11:10 AM
    Beretta4x4
    Josh
    Temple, TX
    Yep. I get a front end clunk every time they're loose.
  20. Dec 9, 2019 at 5:42 PM
    glockner
    Scottsdale, AZ
    So steering wheel vibration is better but not 100%... clunk still seems to be present. I give up at this point. At least I got a new wheel bearing and alignment out of it.
