Tie Rod Damage? Consequences
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Apr 9, 2013.
  1. Apr 9, 2013 at 12:40 PM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Driving cross country notice some sounds and clicking coming from driver-side took it into Firestone here in Tennessee and the mechanic told me that my tie rod which you see pictured in the right encircle is getting some play In it. Was quoted 350 which includes alignment you think this is something I should take care of right now with 2000 miles to go or something I could wait I'm just afraid of a catastrophic failure...
  2. Apr 9, 2013 at 12:46 PM
    Large
    Large Red
    Given the extent of the damage I wouldn't want to be doing 70 MPH and a tire rod give out on the highway
  3. Apr 9, 2013 at 12:50 PM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    What is the mileage in your truck? My outer tie rod ends had some play at about 155k. I drove about 8k before i changed it myself. It is recommended to change both sides if you have to do one. I paid about 43 bucks for a pair of Moogs on Amazon. Took less than 30 mins to put them both on. Then got it aligned.
  4. Apr 9, 2013 at 12:51 PM
    prerunnerSD
    USA
    It just started making noises and I just noticed, is it a huge risk that it could give out should I just fix it anyway? My main mechanic is not around here so I just want to make sure it's done right
  5. Apr 9, 2013 at 12:54 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    If its the outer rod, its easy to fix yourself. Inner rod is a bitmore but also pretty easy. Check out my DIY thread for a vid.
  6. Apr 9, 2013 at 12:58 PM
    jshsltr
    Josh
    St Louis
    When do you hear the clicking? While turning or driving straight? Highway speeds or slower?
  7. Apr 9, 2013 at 12:58 PM
    prerunnerSD
    USA
    If the inner tire rod goes on the left side driver side and I was going 60 miles an hour would the truck crash would I lose complete control the vehicle is it really that big of a deal? My lower ball joint back in the winter stamped and caused the wheel to come off, $2200 worth of repair sense now this comes up
  8. Apr 9, 2013 at 1:17 PM
    prerunnerSD
    USA
    That happens at slower speeds I don't hear it on the highway at all mostly happening only when turning it's kind of a very subtle thing most people would notice it's just I've had problems before so I'm on it. It's happened in the last thousand miles traveling from New England to Tennessee
