Tie Rod End Boot Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by 043RZ, Apr 1, 2014.
  1. Apr 1, 2014 at 9:02 PM
    043RZ
    043RZ [OP] Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Just need a quick question answered. About 10000 miles ago i had my outer tie rod ends replaced... Unfortunately i didn't know any better and had SEARS do the work... NEVER doing that again, but that's a story for another day. Anyway when they installed the tie rods they managed to tear the boots completely. So my question is beings the tie rod ends are practically brand new, can i replace the boots without having to go back and realign the toe in?
  2. Apr 1, 2014 at 9:04 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yeah, just mark where the lock nut is before you take it apart. As long as you tighten it to the same spot you'll be fine.
  3. Apr 1, 2014 at 9:08 PM
    043RZ
    Spring Grove, PA
    2004 Tacoma SR5
    Do i have to mess with the lock-nut at all if im just replacing the outer tie rod boot (the ball joint that connects to the spindle)
  4. Apr 1, 2014 at 10:22 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Nope.....they make replacement boots for those?
  5. Apr 1, 2014 at 10:24 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Easy to do. Take off outer rod and done.
    I ended up pokin a hole in mine when reclamping it... be careful with stock clamps
