Tie rod end question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Noza, Jul 4, 2022.
  1. Jul 4, 2022 at 7:07 PM
    Noza
    Noza [OP] Active Member
    Hi all,
    I changed both tie rod end (left and right) using Moog part. The cotter pin hole on the left tie rod is above the castle nut. The right tie rod no issue.
    Anyone had that happened to them?
  2. Jul 4, 2022 at 7:34 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Maybe the female end where the tie rod goes into is worn out.
    Edit - I had this happen once many years ago on a ball joint; I added a washer under the castle nut.
  3. Jul 4, 2022 at 7:35 PM
    Bishop84
    Bishop84 Well-Known Member
    I've seen it a few times. I just re-seat the tie rod, if it still does it with proper torque, I just pin it and don't worry about it.
    Geeves77, Dekoy909 and ohcaltexscar like this.
