tie rod ends HELP?
Discussion in 'Suspension' started by esse10, Oct 13, 2013.
  1. Oct 13, 2013 at 7:27 AM
    esse10
    esse10 [OP] Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Anybody had problems with the MOOG's es80895 tie rod ends rubber boots tearing up prematurely??? I had mine for less than a year and the left side rubber boots tore up, oky so I relaced with new one, had a front end alingnment done, now the same left side tore up again after only 3 weeks..........uuurrrrgg! I do hear a whuuup whuup whuup coming from my front tires as I go down the road but I thought that was becuase they are worn out and close to replacement. I have the BF Goodrich all terrain tires. Any help would be appreciated or past experience knowledge guys, thanks.......
  2. Oct 13, 2013 at 7:39 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    it sounds like there is definitely something bigger going on. Shocks could be a starting point, but you might have a bad bushing in a control are or even look at your steering rack. Tires could be out of round but that is rather rare. especially for BFGs The boot tearing could be from a sharp edge somewhere on the steering knuckle. But looking at the pic, it appears to be clean.
    I'm throwing darts to be honest.
  3. Oct 13, 2013 at 7:44 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    • On installation, grease the faying surface of the seal where it contacts the spindle.
    • On installation, put the jack under the control arm so the tie rod angles are closer to normal ride height - this so you don't pinch the boot on installation
    • Try a different part, such as Raybestos 4012185, which has a "convex" boot design without the sharp folds that are prone to leakage. http://www.rockauto.com/catalog/moreinfo.php?pk=1328957&cc=1445186
  4. Oct 13, 2013 at 9:47 AM
    esse10
    Texas
    k, thanks guys. Those are a few things to try. I do remember lifting the LCA up on intallation so it would go in even, I did not put grease though maybe i need to try that next time.
  5. Oct 13, 2013 at 2:36 PM
    smd3
    smd3 Well-Known Member
    That boot looks like it's been pinched in, where I would expect it to bellow out in the middle.
    Is that your truck pictured in your avatar, or is it lifted?
  6. Oct 14, 2013 at 10:08 AM
    esse10
    Texas
    Yes that is my truck and no it's not lifted. I can't figure out how that got pinched but guess I'll try the grease concept some time in the near future.
  7. Oct 14, 2013 at 10:14 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Ive had Moog tie rods on my 08' Tacoma for almost 2 years with no issues.
    Only thing I did was flush that crap grease out they come with and filled them with Mobil1.
