Tie Rod Ends
Discussion in '1st Gen. Tacomas (1995-2004)' started by hucker, Apr 21, 2010.
  1. Apr 21, 2010 at 12:32 PM
    hucker
    hucker [OP] Member
    boise
    2000 PreRunner
    Big air repair custom bumper Magnaflow cat back Airraid Spacer Spectre intake Hood Spikes
    Hey, I have a 2000 tacoma prerunner and the joint on the end of the right side tie rod is shot. The wheel has about an inch of paly when lifted of the ground. Do I need to replace the whole tie rod end or can I just replace the joint? Anybody ahave a linky to a DIY? If not I gues I'll have to make one when I do it. Thanks
  2. Apr 21, 2010 at 2:41 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    yes it can be replaced it is called a outer tie rod or tie rod end if you want to look it up very easy to install just make sure to get an alignment asap
  3. Apr 21, 2010 at 2:50 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Check www.rockauto.com for the part.
    Best prices I've found for just about everything, and they're an approved TW vendor.
