Tie rod locking nut loose?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 11Bravo4x4, Jul 25, 2019.
  1. Jul 25, 2019 at 11:47 PM
    eon_blue
    Azusa, CA
    Thanks ya I think the confusion is stemming from the original worded description that sounded like the OTRE to me
    RangerComa[QUOTED] likes this.
  2. Jul 26, 2019 at 11:41 AM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    My bad! I meant there is no cotter pin in the jam-nut pictured. Of course there's one where the outer tie rod end connects to the knuckle.
  3. Jul 26, 2019 at 11:50 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    A lot and I mean a lot of bad information here until G8R correctly identified the part as a jam nut. There is really nothing dangerous about it being loose. I mean it could potentially back out, but if you have ever had to turn and adjuster with a pipe wrench or had to get out your torch to loosen a tie rod end, you realize that the nut doesn't do much. If by chance the rod backed itself all the way out, you would be in some serious peril which is what it is there for.
    I wouldn't worry about it beyond just snugging them up on each side. You could take it back and make them check the alignment to give you peace of mind, but chances are very, very slim there has been any change.
  4. Jan 30, 2022 at 4:11 PM
    Kristi with a K
    Kristi with a K Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    Years later, but just wanted to add to this. I am having a rotational vibe right side. Passenger can feel it through the footboard.
    Anyway, jacked it up & had play at 9 & 3. I grabbed the tie rod & by chance noticed the nut was loose. I tightened the nut & the play is gone. Had an alignment a couple/few weeks ago.
    Alls I’m sayin’ is while it may not be considered dangerous, my guess is it could take a toll on other parts. Good to keep an eye out for this.
    Now my axle is making a clicking noise when I quickly turn the wheel back & forth. Any relation? I dunno.
    Sucks when ya keep doing things over & don’t know if it was me or a loose nut or ????
