Tie rod question?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Jan 20, 2012.
  1. Jan 20, 2012 at 5:01 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    i need to replace my tir rods but what do i actually replace...i have a little wigglw in the wheel and the rack is moving.....do i just do steering bushing and tie rod ends? or do you replace the whole tie rod? need help my tires wont get alighnid and crowning bad
  2. Jan 20, 2012 at 5:06 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    how many miles on ur truck? I just replaced my bushings and inner and outter tie rods. @ 280k miles.
  3. Jan 20, 2012 at 5:10 PM
    sir1123
    Charleston
    215xxx ....so i should do inner and outer?
  4. Jan 20, 2012 at 5:12 PM
    sir1123
    Charleston
    but what on the inner tie rods wears out i see no bushing or ball jints on the inners
  5. Jan 20, 2012 at 5:15 PM
    goomba
    Josh
    San Antonio Fl
    The inners are covered by a boot. I did mine by myself. I would deff reccomend doing both and if u get some wondering on the highway i would buy the bushings from wheelers and u can do them urself easily.
  6. Jan 20, 2012 at 5:16 PM
    goomba
    Josh
    San Antonio Fl
    Inner tie rod
  7. Jan 20, 2012 at 5:21 PM
    sir1123
    Charleston
    i have no wandering just the alignment wont stay....i have a rack bushing and have replaced all sway bar bushings already..... i guess it makes sense do do both inner and out all at once.......thanks boss sounds like a trip to Parks auto in the a.m.
  8. Jan 20, 2012 at 5:25 PM
    goomba
    Josh
    San Antonio Fl
    I would recomend u do it urself. labor is sometimes pricey, and u could get moog parts cheep from Amazon. Glad i could help
  9. Jan 20, 2012 at 5:36 PM
    sir1123
    Charleston
    ya man i do all my truck labor...lots of info and youtube to watch for help
  10. Jan 20, 2012 at 5:41 PM
    goomba
    Josh
    San Antonio Fl
    ok. good luck
  11. Jan 22, 2012 at 9:10 PM
    sir1123
    Charleston
    so i re checked my tie rods and there is no play in either of them.....so i just did the rack bushiings....my tires are crowning and have uneven lug wear....should i just get it re aligned? what else could the wear be due to? it has been aligned and they said it would probebly not hold due to my tie rods......they are solid as i rock the shop was trying to screw me out some money i guess.....don't tie rods adjust toe and not camber anyways.....any help appreciated.
