Tie Rod Replacement after 15K Miles?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 617sov, Mar 5, 2024.
  1. Mar 5, 2024 at 2:02 PM
    617sov
    617sov [OP] Member
    Got some Play in my front wheels when parked. State Inspector is claiming a I need new tie rods. Had tie rods replaced 15k Miles/18Monthes ago by a local shop. Truck is lifted 3" on Kings/Bilsteins.
    Any Other components that could cause one to be able to move/manipulate front wheels when parked aside from Tie Rods?
    Could a lifted Suspension cause premature Failure?
    Scratching My head on this one.
    Bivouac likes this.
  2. Mar 5, 2024 at 2:04 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Inner or outer? Which were replaced last time? Is the steering rack in good shape?
    Bivouac likes this.
  3. Mar 5, 2024 at 2:11 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    If that shop used cheap tie rods (Moog, etc..) then yeah, they could fail in 15k.
    Yes- the steering rack bushings are commonly replaced to reduce movement in the steering rack. I'd have a friend move the steering wheel side to side while looking under the truck yourself to see what's moving.
    Area51Runner and 617sov[OP] like this.
  4. Mar 5, 2024 at 2:29 PM
    617sov
    617sov [OP] Member
    Both inner and outset tie rods were replaced. Not sure if OEM or Aftermarket.
    Steering Rack was replaced at same time. Vehicle was in front end collision.
  5. Mar 5, 2024 at 2:49 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Bad ball joints. Loose control arm bolts. Bad wheel bearing can also do it, but usually you hear it before it develops play.
  6. Mar 5, 2024 at 5:19 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    In your state do the inspection people do repairs ??
    Often I have had them say things were failed only to find they were just looking for work from the clueless.
    I do wonder just what Brand rack was installed?
    Good Luck !
    MalinoisDad and Area51Runner like this.
  7. Mar 5, 2024 at 6:38 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Never heard of state inspection failing bc of suspension
    Unless obvious/tons of movement in suspension
    yes a lift can prematurely wear out suspension bits…..just bc previous engineered geometry has changed
    Firstly, Jack up a front corner
    Grab the tire at 3 and 9 o’clock and shake……if noticeable play….inr or otr ties
    Grab tire at 12 and 6 o’clock and shake
    If noticeable play could be wheel bearing/upper or lower ball joints/inner control arm bushings
    have a buddy ‘shake’ and you under with flashlight…..look at all suspension connection points
    My guess is lwr ball joints
    Search, lots of easy tests to do without jacking the taco up, but do need a pry bar
    let us know what u find!
  8. Mar 5, 2024 at 8:06 PM
    617sov
    617sov [OP] Member
    Thanks for all the suggestions. Will report back!
    ControlCar likes this.
