Tie Rods, Tie Rod End Question
Discussion in 'Technical Chat' started by Toy4Life, Feb 20, 2009.
  1. Feb 20, 2009 at 5:01 PM
    Toy4Life
    Toy4Life [OP] 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I bought a fixer upper 92 4Runner 4x4 V6. I'm trying to diagnose a steering/suspension issue. I noticed, somewhat at random, that the front wheels will shimmy severely. I have it up on jack stands and the wheels have quita a bit of play side to side. Is this tie rods or ball joints? If it is tie rods, how do you figure out which tie rod end needs replaced.
    Also, is it just coincidence that this problem wasn't evident during a previous test drive or during the 60 mile drive home after purchase? The very next time I drove this 4Runner after bringing it home. this problem surfaced.
    Any help is appreciated.
  2. Feb 20, 2009 at 5:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Hard to tell from your description. Grab the TRE's and see if you can feel if they are loose.
  3. Feb 20, 2009 at 5:56 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I'll look into it. I've never dealt with tie rods before.
  4. Feb 20, 2009 at 6:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You amy want to look at the steering rack bushings, as they will cause some shimmy if the rack bushings are gone.
  5. Feb 20, 2009 at 6:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oh, and to check the ball joint, remove the tire, and pull on the spindle to see if you can feel any movement in the joint.
  6. Feb 20, 2009 at 6:14 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Sorry Chris, compared to the Tacoma, this runner is very foreign to me. The Tacoma was my 1st 4wd. This.........it's like starting from scratch. The tie rod ends seem a little loose and the little grease boots are torn. I'm guessing that alone is enough to replace them.
  7. Feb 20, 2009 at 6:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. Thats a good indicator.
  8. Feb 20, 2009 at 6:23 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Thanks Chris. I'll look into the rack bushings as well.
  9. Feb 20, 2009 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I cant remember if the 94 Runner has a R&P or Rec. Ball. I'll see what I can dig up.
  10. Feb 20, 2009 at 6:29 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I can't find a rack.
  11. Feb 20, 2009 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its a Rec. Ball steering. Not hard to work on.
  12. Feb 20, 2009 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you get my PM?
