Tie rods
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, May 29, 2015.
  1. May 29, 2015 at 11:33 AM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    How do I know if they need to be replaced? The right side boot is ripped on one. Truck has 387K on it. Ball joints have been replaced. Tundra brake upgrade done about 15K ago. The reason I'm asking is yesterday had to do a 70 mph panic stop and the truck swerved real quick to the left then back to the right.
  2. May 29, 2015 at 12:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Take the weight of the truck off of a front wheel. Grab the wheel in the 3 and 9 o'clock positions and see if you get any movement. Movement is this direction is either tie rod or steering rack. If there is movement, you should be able to see where it is.
    ramonortiz55 likes this.
  3. May 30, 2015 at 1:27 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your changing the outer Tie Rods make sure the adjusting nuts are free before going for your alignment
  4. Jun 24, 2015 at 12:31 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    yep. I got a little movement. Thanks.
  5. Jul 9, 2015 at 12:57 PM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Remind me to never replace tie rods again. Almost 7 hours later and they're done. The shop that aligned it told me they would have done 'em for $90 bucks.
  6. Jul 9, 2015 at 2:20 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    7 hours?????
  7. Jul 9, 2015 at 4:16 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
  8. Jul 9, 2015 at 10:21 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  9. Jul 9, 2015 at 10:26 PM
    trx125
    trx125 Well-Known Member
    Two big crescent wrenches, needle nose pliers and BFH. 30 minutes for both sides(that includes 2 beer breaks per side).
    DOUBLLD likes this.
  10. Jul 10, 2015 at 1:08 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Just what kind of problems did you have that it took that long Pray tell??
    Then maybe you truck came from the great Brine Belt !!
  11. Jul 10, 2015 at 4:04 AM
    Sundowner
    Sundowner Member
    2002 Tacoma TRD X-cab
    optional rusty everything has been progressively installed over the past 14 years
    Tie rod ends usually give up after 3-4 whacks with a 5 lb mallet. I had one that would_not_let_go. 5 lb hammer, 20 lb sledge, MAPP heat, bottles of PB blaster, it did not matter. even dedicated rod end pullers and hydraulic 12 tn gear pullers would not budge it. Finally pulled the tie rod end out of the rack and use a cut-off saw to slice the arm off on the lower ball joint. At that point of frustration, a new lower ball joint was cheaper than my sanity.
  12. Jul 10, 2015 at 6:35 AM
    keakar
    karl
    louisiana
    to each his own but that's why that tool I linked makes it a 5 minute job with no hammer needed at all.
    it simply presses the shaft of the tie rod out of the hole in a clamping manner so its done safely and with little to no effort.
    yes the hammer works "most of the time" but you depend on it to break itself free instead of applying direct force to make it come out.
    I used pickle forks and hammers for years but when I finally bought this tool I had no idea how easy it was to remove tie rods and ball joints with the turn of a wrench instead of brute force
  13. Jul 10, 2015 at 7:46 AM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    5 hours on the drivers side. 2 on the passenger side. Heat, 3 lb. hammer, 4 different kinds of pullers. The BFH and heat finally worked. No rust issues but 390,000 miles on 'em may have had something to do with the amount of force and heat I had to use.
  14. Jul 10, 2015 at 7:49 AM
    keakar
    karl
    louisiana
    with that many miles on it i would have just unbolted the lower ball joints and replaced them too instead of fighting it that long.
    to be honest i cant believe the ball joints didnt also need replacing but im sure you checked them
  15. Jul 10, 2015 at 1:40 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Those are a great tool for popping out tie rods.
    I have the otc tool for the older ball joints and A C type press for the newer style the work great.
  16. Sep 8, 2015 at 8:34 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Would this tool also work? I got it to do the upper control arm job but I ended up not needing it. Now I wanna do the tie rods and I wanna have the right tool :D
  17. Sep 8, 2015 at 9:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm not sure it would but worth a try I suppose. The thickness of the to arms may be an issue.
    This is the puller I used.
  18. Sep 8, 2015 at 9:17 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Is the tool needed just to get the outer tie rod out of the knuckle/spindle?
    I think I am getting a complete rack from Rack Doctor so that's all I would need.
  19. Sep 8, 2015 at 9:20 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    did them on my 4runner this weekend..
    that tie rod end puller sure makes things easier..keeps your sanitie in check
  20. Sep 8, 2015 at 9:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The outer tie rod connects to the ball joint, not directly to the spindle. Check this out.
