tie rods
Discussion in 'Suspension' started by rab89, Nov 26, 2009.
  1. Nov 26, 2009 at 3:17 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    Is it normal to be able to twist my tie rods back and forth with my hand?
    and should they click/clunk like metal on metal when I do?
  2. Nov 26, 2009 at 3:23 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Make sure the two nuts on either tie rod are tightened, especially the ones closer to your wheels. Those should have locktite on the threads. The inner nut is loosened to adjust your toe. If that nut is loose, your truck will eventually be out of alignment. If both nuts are tight then you should not be able to adjust your tie rods.
  3. Nov 26, 2009 at 3:26 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    Are you able to turn the rod or the end or do they turn together?
  4. Nov 26, 2009 at 3:28 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
  5. Nov 26, 2009 at 3:28 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    The Tie rod end is a joint so movement is ok, best way to check is to have someone move the steering wheel slightly back and forth while you grab on to the tie rod and check for popping/play in the joint
  6. Nov 26, 2009 at 3:43 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ yea its ok for the entire tie rod to move as ONE piece, but you shouldnt be able to twist the tie rod in opposite directions by twisting the outer and inner tie rod ends.
  7. Nov 26, 2009 at 3:47 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    im pretty sure you need new tie rods with that much movement :)
  8. Nov 26, 2009 at 4:06 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    DAMN, ok so, how hard is it to replace them? and anyone know a good place to buy them?
    also, when jacked up, my wheel has play going in and out, so standing at the side of the truck with a hand on either side of the tire i can jiggle it. tie rods? would that give me a clicking sound over bumps?
  9. Nov 26, 2009 at 4:16 PM
    Yoytoda
    Roland
    completely stock
    Tie rod ends. the tie rod is probably fine. Take the wheel off take the nut off the "ball joint" take a "ball joint fork" pop it out, heat may be required. When taking the rod end off count the turns off. when installing the new one put on with same number of turns. get it alligned
  10. Nov 26, 2009 at 4:25 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    Sorry I meant tie rod ends as yoytoda mentioned. If it were me go to a shop like midas and get them to look at the front end and tell (and show you) what is worn out and then go to a parts store get the needed parts and install them
  11. Nov 26, 2009 at 4:28 PM
    Yoytoda
    Roland
    completely stock
    x2
    I just posted how to fix them but withou looking at the truck no guarantees thats the problem.
  12. Nov 26, 2009 at 7:47 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    thanks for all your help guys, i had kaltire do a tie rod end last year, so i'll go back and get them to check it for free :)
  13. Jan 18, 2010 at 1:22 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    so I posted somewhere else but this works, turns out it's both inner tie rod ends, where should I buy new ones online?
