Tierod ends and ball joint replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperpete52, Jul 26, 2016.
  1. Jul 26, 2016 at 4:57 PM
    Trapperpete52
    Trapperpete52 [OP] Well-Known Member
    Pete
    98 Tacoma 4 X 4 5 speed 93 Tacoma 4 X 4 5 speed 95 Tacoma 4 X 4 5 speed
    roll bar and lights
    Working on a 95 4 wheel drive that has suffered a lot of road cancer from Iowa winters. Has anyone tried the GSE brand of tierod and ball joints from Ebay?
    The passenger side tierod has a regular nut on it that I am thinking will have to cut off. Been trying to break it loose with my 24" snapon breaker bar and electric impact. So far hasn't budged a bit. Found top ball joint has NO cotter key as well.This truck is turning out to be quite the adventure.
    Top shock mount passenger side rear had rusted and broke out. Patched it up as is way past the cut off for replacement though has less then 200,000 mile on her.
  2. Jul 26, 2016 at 5:34 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    Most people say go for OEM ball joints due to their build quality. I'm not sure exactly what it is that makes them better but a member here cut one in half to compare it to other manufactures and concluded that OEM was worth the price for the quality.
  3. Jul 26, 2016 at 8:15 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Go OEM. This is one of those parts you do NOT want to cheap out on.
    Fenwick1993 likes this.
  4. Jul 27, 2016 at 2:26 AM
    jjsul
    James
    New Hampshire
    95.5 OME
    FWIW I went OEM
  5. Jul 27, 2016 at 8:26 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Our trucks have a strange design. They literally hang from the lower ball joint rather than rest on the lower ball joint. My father and I are replacing our lbjs with OEMs this fall as preventative maintenance. I probably will go moog on the other parts.
    jjsul likes this.
  6. Jul 27, 2016 at 8:40 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    I picked up Moog inner and outer tie rods for my 02, very happy with the quality. haven't had to do ball joints yet, so can't speak to that...
    jjsul likes this.
  7. Jul 27, 2016 at 10:03 AM
    1997tacomav6
    Denver
    Spend the extra money and fix it once for this part, other parts you can buy after market but don't risk this one. If something goes wrong with after market part you will crash and burn. Buy only OEM , I just replaced those on my truck at 490,000 miles,
    Ball joints and tierods and steering boots,
  8. Jul 27, 2016 at 10:29 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Literally
  9. Jul 27, 2016 at 12:07 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Known as a nonfailsafe design. Once it fails your done for.
    Ive been using moog lbs for a couple years now with no issues.
    I still recommend oem though.
  10. Jul 28, 2016 at 4:53 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I went moog for the TREs, but if and when the LBJs need replacement, will probably go OEM.
  11. Jul 28, 2016 at 4:08 PM
    Trapperpete52
    Pete
    roll bar and lights
    Thanks all for the input.
  12. Jul 28, 2016 at 6:29 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Ill see if i can find the comparison video but oem is by far the superior build for this part.
