Tiffany the Taco
Discussion in '1st Gen. Builds (1995-2004)' started by nzbrock, May 17, 2015.
  1. Aug 3, 2018 at 8:22 AM
    #201
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    :thumbsup:
    nzbrock[QUOTED][OP] likes this.
  2. Aug 12, 2018 at 8:12 AM
    #202
    nzbrock
    nzbrock [OP] Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    So I have been chasing a turn signal and running light issue that causes my turn signals to come on when I press the brakes. I have also always an issue with my turn signal indicators coming on whenever I turn on my running lights. This has been occurring ever since I installed 1157 switchback bulbs in place of the stock 1156 bulbs.
    Yesterday, after a lot of research, I realized that 01-04 tail lights are wired slightly different from 95-00. The 95-00 lights ground on both sides, but the 01-04 use only 1 ground for both lights. This means that almost all aftermarket 01-04 lights are wired the same way and will have an extra pin for ground on the driver side. This isn't an issue unless you have a trailer harness. The trailer harness also falls prey to the issue of all aftermarket companies lumping 95-04 into the same category. The trailer harness is actually wired for this 2nd ground, so on my 99 truck, it is connecting that ground to something else through the trailer harness. I removed the extra wire on the tail light and it solved the issue of the brakes back feeding power into the turn signals.
    I still have an issue with my turn signal indicators coming on with the running lights, but this may be an issue with the 1157 switchback bulbs themselves. Somehow power is traveling though the running light wire and into the turn signal circuit. It is only illuminating the turn signal indicators on the dash. Everything else still functions properly.
    If I ever pull the gauge cluster out again, I will probably switch the indicator bulbs back to incandescent, which will most likely solve the problem.
  3. Sep 6, 2018 at 2:51 PM
    #203
    nzbrock
    Noah
    San Marcos, TX
    Got a good spot at the end of my street.
  4. Sep 6, 2018 at 3:33 PM
    #204
    cazinpa
    cazinpa Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    I use Solidworks. It imports iges and lots of other formats.
  5. Sep 19, 2018 at 3:45 PM
    #205
    nzbrock
    Noah
    San Marcos, TX
    Started working on my Ultimate 1st Gen Mirrors
    boostedka likes this.
  6. Sep 19, 2018 at 5:01 PM
    #206
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Going to have built in turn signals?
  7. Sep 19, 2018 at 5:08 PM
    #207
    nzbrock
    Noah
    San Marcos, TX
  8. Sep 19, 2018 at 6:54 PM
    #208
    boostedka
    James
    NM
    Nice! Those are coming out pretty slick so far. Can’t wait to see the finished product.
  9. Sep 20, 2018 at 2:47 PM
    #209
    nzbrock
    Noah
    San Marcos, TX
    Made some more progress on the ultimate mirrors.
    Courtesy Light (I will wire this to my stock courtesy light wiring, sucks you 01-04 guys don't have that).
    Turn signal
    Arctic Taco, Jvance1994, Wulf and 2 others like this.
  10. Oct 20, 2018 at 2:29 PM
    #210
    nzbrock
    Noah
    San Marcos, TX
    Finally finished my ultimate mirrors with puddle lights, turn signals, and heaters!
    unstpible, Jvance1994, erice and 2 others like this.
  11. Oct 20, 2018 at 7:23 PM
    #211
    boostedka
    James
    NM
    Wow! Those things came out awesome. Excellent work!
    nzbrock[OP] likes this.
  12. Oct 21, 2018 at 10:19 AM
    #212
    Wulf
    Wulf no brain just damage
    rock raisin
    Those mirrors are sweet! Were you able to order the signal light only, or did you have to order the whole mirror?
  13. Oct 21, 2018 at 12:11 PM
    #213
    nzbrock
    Noah
    San Marcos, TX
    It comes as the plastic mirror housing only. No glass, motor, or mount.
  14. Nov 11, 2018 at 10:21 AM
    #214
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    Love the power folding feature! nice truck man
    if you ever decide to put together a group buy for those mirrors. let me know. :thumbsup:
  15. Nov 11, 2018 at 10:24 AM
    #215
    nzbrock
    Noah
    San Marcos, TX
    My mirrors aren’t power folding. I am on the lookout for some from a hilux surf, but they are hard to find.
    04yota[QUOTED] likes this.
  16. Nov 11, 2018 at 10:40 AM
    #216
    04yota
    Angelo
    Central New Jersey
    Oh i see. Still look cool as heck. Where did you wire the cables for the heating option
  17. Nov 12, 2018 at 3:54 AM
    #217
    nzbrock
    Noah
    San Marcos, TX
    I am triggering a relay in my RTMR Fuse/Relay box from the defrost switch behind the HVAC controls. So whenever I turn my HVAC to defrost it will turn on the mirror heaters.
  18. Nov 23, 2018 at 11:08 AM
    #218
    Yucel
    Yucel Well-Known Member
    San Francisco Bay Area
    2023 Tacoma TRD Sport
    Do you have a write up on your suspension? And can you also give an analysis/comparison before vs now...how you like it.
  19. Nov 24, 2018 at 6:58 AM
    #219
    nzbrock
    Noah
    San Marcos, TX
    No write up. I wish I had gone with lighter coils in the front, the standard 650# are a little stiff for the 4 cylinder. The Wheelers 5 leafs are great as well, but now I'm considering an AAL after adding the topper.
  20. Nov 25, 2018 at 9:51 AM
    #220
    nzbrock
    Noah
    San Marcos, TX
    Went up to Ricketts Glen for Thanksgiving. It started snowing without about 45 minutes left in the drive and got a little sketchy coming into the cabin site. This is what it looked like the next morning.
    erice, TacoBessy and boostedka like this.
