Tight brake lines after 6" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZERO COOL TACO, Sep 25, 2008.
  1. Sep 25, 2008 at 12:23 PM
    ZERO COOL TACO
    ZERO COOL TACO [OP] Member
    western north carolina
    2008 Double Cab TRD Rugged Trail
    6 inch fabtech suspension lift
    Since the addition of my 6" fabtech lift i noticed that the break lines all seem uncomforably tight. I feel like if I really flexed the suspension to one side that I could break a line. Am I suppose to buy some sort of extensions ?????
  2. Sep 25, 2008 at 12:32 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    with a 6" lift? hell yes
  3. Sep 25, 2008 at 12:51 PM
    ZERO COOL TACO
    sorry i know nothing about a lifted vehicle this is my first. the instructions said nothing about it. where would i get them?
  4. Sep 25, 2008 at 12:51 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  5. Sep 25, 2008 at 12:54 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    toytec offer some
  6. Sep 25, 2008 at 12:55 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    +1 for wheelers!
  7. Sep 25, 2008 at 1:07 PM
    ZERO COOL TACO
    I guess I'll park it and ride my motorcycle till I can get those put on. I had no idea. Thanks for pointing the way for the modification virgin
  8. Sep 25, 2008 at 3:14 PM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Is this something that you just inspect on a one-of basis, checking the lines? Or do you just get the longer lines when you lift, no matter how much you lift?
  9. Sep 25, 2008 at 3:27 PM
    JimBeam
    JB
    2015 Tundra
    well for 0-3 inches is one of those check and see situations...but for a 6 inch lift itd be a pretty typical step
  10. Sep 25, 2008 at 4:38 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    did u install the lift yourself? how hard was it and how long did it take u?
  11. Sep 25, 2008 at 7:09 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    check out crown performance. they have great prices and a ton of colors if your into that kind of things.
    you can get lines for around $25 each.
  12. Sep 25, 2008 at 11:58 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    +2 for wheelers! Buy from them. Great people!
  13. Oct 1, 2008 at 11:15 AM
    ZERO COOL TACO
    Well this is my first lifted vehicle and yes man i installed it myself. Its sort of intimidating for someone like me with minimal mech experience. You have to take nearly everything off of the front end and you cut your cross member off of the frame which is nuts on a brand new truck. Also i voided all my warranties when i chose this lift.
  14. Oct 1, 2008 at 11:24 AM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    ^^^damn, someone has balls...
  15. Oct 1, 2008 at 12:13 PM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    I got my extended brake line from Wheelersoffroad u can get away with not using extended brake lines on a 0-3" lift as long as you don't wheel.........if you flex and see them stretch...def get the extended lines.
    6" you should get them no matter what
  16. Oct 1, 2008 at 12:18 PM
    1bad03snake
    1bad03snake Well-Known Member
    Baytown,TX
    4x4 TRD
    none but please give me your info.
    After I voided the warranty on my 08 GT500, I no longer have the balls to do anything like that. My dealer said I wont void anything when I add my 3" this weekend.
  17. Apr 30, 2009 at 10:38 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Toytec brake lines are longer then stock. FYI I called them and checked.
  18. Apr 30, 2009 at 10:59 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Old thread is old. :)
  19. Apr 30, 2009 at 11:06 AM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    You guys are awesome, I never even thought of that. looks like i will need to pick up some brake lines after i get my lift in June. hey ZERO COOL TACO, where they so tight that you thought they would brake during any kind of wheeling or just maybe they might if you were in some harry shit?
