Tight steering
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dberneski, Jan 8, 2025.
  1. Jan 8, 2025 at 9:22 PM
    Dberneski
    Dberneski [OP] Member
    David
    2020 Cement trd off-road taco
    Tonneau cover, running boards, interior led kit, ridge grapplers 265/75/16
    I recently got a spacer lift installed, 2” front 3” rear. I did supply the parts, 1 1/4” wheel spacers and new UCA’s. Since the lift was put it I noticed that the steering is super tight wish is nice but the steering wheel does not return back to center freely, and yes, I had an alignment done. Has anyone else experienced this or have any thoughts? Ty!
  2. Jan 8, 2025 at 9:31 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  3. Jan 9, 2025 at 5:36 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I would take it back to the alignment shop and have them check it out.
  4. Jan 9, 2025 at 6:15 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
  5. Jan 9, 2025 at 8:04 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    Your alignment may be good but your tie rod ends are offset in one direction or the other. Take it back to the alignment shop and have them adjust the tie rods an equal amount in whichever direction it takes to center the steering wheel.
    SH10151 likes this.
  6. Jan 9, 2025 at 8:08 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Before you spend any more money, post your alignment sheet.
  7. Jan 9, 2025 at 8:28 AM
    Dberneski
    David
    Got it thanks guys. I didn’t think about the tie rod ends.
  8. Jan 9, 2025 at 8:38 AM
    eurowner
    eurowner Duke Sky
    Scoty
    The caster needs to be addressed correctly.
    https://www.motor1.com/news/299470/why-front-wheels-return-center/
